Does anyone know the wiring conversion for 95 D16Z6 into an 89 CRX.
Old Jan 13, 2003 | 09:57 AM
I Gotta Question's Avatar
Default Does anyone know the wiring conversion for 95 D16Z6 into an 89 CRX.
I did the wiring converzion and now my temp gauge shoots up and the check engine light come on when I put the key in the run pos. . The car won't start either. Has anyone had this same problem? If so tell me how you fixed it.
Old Jan 13, 2003 | 11:04 AM
zCivic's Avatar
Default Re: Does anyone know the wiring conversion for 95 D16Z6 into an 89 CRX. (89_CRX_HF)
Maybe the temp sensor is bad or not hooked up. Its under the distributor its a single prong just unbolt it and swap it with one you know works. Also did you change the fan switch in the back of the block from a singe prong to the 2 prong? I know my 92 just switched out heard that 94 they changed the location that may be another problem.
SpoonMotorSport
Engine Management and Tuning
14
Apr 21, 2013 03:07 AM
projsectEF
Jun 7, 2006 02:31 PM
metalmulisha420
Mar 2, 2006 06:35 AM
senate33
13
Oct 11, 2005 08:29 PM
quidquam
Sep 4, 2001 07:45 PM
