I can use this gauge cluster, right?
Old Jan 13, 2003 | 09:08 AM
HGZ's Avatar
HGZ
Default I can use this gauge cluster, right?
I just bought (won) this from ebay as a replacement for my 90 civic si. The tach in my original cluster doesn't move accurately with the rpm change, so i need a new one. But i just noticed that the cluster i won redlines at 5. I have reverse indiglo gauges, which show the redline at 6.5, so of course i'll be laying them over the stock gauges, but there really is no difference between the two clusters, except for the way the gauges are printed, correct? I'm looking at this picture and the only other difference i see from my original cluster is the extra indicator light at the bottom left hand corner, which has a white outline around it. I can still use this as a replacement with no problem, right?
Old Jan 13, 2003 | 09:12 AM
Timmah!!'s Avatar
Default Re: I can use this gauge cluster, right? (hgzee)
That is a CRX HF cluster, I think it is plug and play, Because I think an Si is a plug and play for me and I have an HF
Old Jan 13, 2003 | 09:18 AM
FUP23's Avatar
New User
Default Re: I can use this gauge cluster, right? (azroth)
88-89 cluster will not fit in 90 -91's and 90-91 wont fit 88-89's. Just make sure the cluster matches your cars years
EDIT: Just saw you have a 90 sorry ..
[Modified by Devin17, 1:18 PM 1/13/2003]
Old Jan 13, 2003 | 09:27 AM
philly-O's Avatar
Default Re: I can use this gauge cluster, right? (Devin17)
if using indiglo gauges just pull the bulbs out of the cluster, that way you wont get "shadows" of anything behind the gauges especially the 5100 redline.
Old Jan 13, 2003 | 10:16 AM
Outsane's Avatar
I put a 90si guage cluster in my 88si..
You can swap the parts from your cluster and the new one... too..
Took some work and repinning..
but no it doesn't exaclyt fit with out swapping some brackets.
Old Jan 13, 2003 | 10:23 AM
Cory man's Avatar
Default Re: I can use this gauge cluster, right? (Outsane)
here is a little more info on clusters. The 88 si and the 89 lx 4 door clusters are the same. The 89 si clusters are year specific. The 90-91 clusters all interchange. More info than anyone probably wanted to know.
Old Jan 13, 2003 | 12:06 PM
JaiDM's Avatar
Default Re: I can use this gauge cluster, right? (Cory man)
i have a 89 SI cluster for sale. hehe.
yeah a HF will work in your DX OR SI? as long as its the same year. if not then you will have to do a few mods. and yes its just printed, it will not change your rev limit or anything. it will just look nuts when your 2 or 3000 RPM's over the HF rev limit. hehe
wongburger
Dec 13, 2009 08:39 PM
Project_EF
12
Feb 11, 2005 07:19 AM
fast90hatch
Dec 19, 2004 07:23 AM
E-lude78
Jun 5, 2003 01:20 PM
Civic89
Jul 18, 2002 10:34 AM
