Camber Kit
Old Jan 13, 2003 | 08:05 AM
JackAcc's Avatar
Default Camber Kit
I recently had my 94 ex lowered and the mechanic at the shop told me that I should not have bought the cambers for it. I lowered it 2 inches. He said that he could have bent something in the front that would have been just as good. I am aware of the longer bolt and washer trick in the back, but I have never heard anyone talk about being able to correct the camber in the front by bending something. Does this sound right?
Old Jan 13, 2003 | 11:55 AM
Accord_Munch's Avatar
Default Re: Camber Kit (JackAcc)
Um, I would say no to this. I don't have a camber kit .. of course my car isn't as low as your car.
Old Jan 13, 2003 | 11:57 AM
urbanlegend21's Avatar
New User
Default Re: Camber Kit (Accord_Munch)
can you bend stuff to correct it=yes
will it create more problems than fixing=yes
is your mechanic a moron=yes
so do you want to do that=no
Old Jan 13, 2003 | 02:04 PM
JackAcc's Avatar
Default Re: Camber Kit (urbanlegend21)
I'm with you on all accounts... He told me today he wanted to remove the cambers and bend the control arms to stop them from hiting the inside of the wells (which is causing the clicking I am guessing) I opted for the NO and took my car back, never to return again.. (at least he took the grease stains out of my seats this time...) He also said the noise could be coming from the part of the coilover where the spring hits at the bottom, where it adjusts.... ??? possible?? It still clicks... after all that..... I'm fed up!!
Old Jan 14, 2003 | 06:57 AM
EndlEEsss's Avatar
are you sure the springs are set/resting correctly on the strut?
are they installed right side up?
Old Jan 14, 2003 | 08:39 AM
JackAcc's Avatar
Default Re: Camber Kit (TweakMeUp)
Actually, I'm not sure. I had them installed at a local shop. I would hope they are in the right way.... I honestly did not have the tools or the knowhow to do it. How can I tell by looking a them?? I am not sure if the springs are resting correctly either...??
integraboi1010
Oct 21, 2006 03:51 PM
mikeunreal
Suspension & Brakes
10
Nov 20, 2005 07:26 PM
jerry5150
Jun 30, 2005 08:29 PM
itsJDMyo
13
Jan 7, 2005 10:40 AM
