gsr and ls gauge cluster interchangable?
i think only 94-97 can interchange and only 98-01 clusters can interchange. you would have to consider if the cluster is an auto cluster or a manual cluster since the auto has the shift indicator on the rpm gauge. you can swap out the individual gauges itself as long as the main cluster panel works with your car. also, the redline on the gsr cluster will be higher than the redline of an ls of course. hope this is helpful
EDIT: another thing, the 94-97 gauges are a dark grey color while the 98-01 gauges are a black color
[Modified by slomob18b, 6:02 AM 1/13/2003]
the redline on the ls gauge wouldn't affect a gsr other that you'd be shifting past the 7 thousand something redline during 10/10ths driving right? thanks for your input
