base parts for sh? compatibility question.
Old Jan 13, 2003 | 02:56 AM
joblow's Avatar
Default base parts for sh? compatibility question.
anyone know if the body for the sh and base types are the same? i'm looking at a great deal on a base side and rear lips for my sh.
and does anyone know if the clutch from base type will work on my sh?
thanks in advance.
Old Jan 13, 2003 | 05:05 AM
Mikeyslude's Avatar
Default Re: base parts for sh? compatibility question. (joblow)
the body is identical and the clutch is interchangable. The suspension setup, cams, and tranny are the only real differences. Check a Helmes manual just incase though.
Old Jan 13, 2003 | 10:41 AM
DsITR's Avatar
Default Re: base parts for sh? compatibility question. (Mikeyslude)
yes both will work..
SH comes w/the same kit as the base, it is just painted.
clutch is identical ATTS is not.
Old Jan 13, 2003 | 11:57 AM
Shakes's Avatar
space cadet
Default Re: base parts for sh? compatibility question. (dsludefosho)
what is different about the cams?
Old Jan 13, 2003 | 01:55 PM
SuperSH's Avatar
Default Re: base parts for sh? compatibility question. (shakes)
The SH's have a slightly higher profile (1.5 MM?) but shorter than the type s cams and this is only on the Vtec lobe.
Old Jan 13, 2003 | 02:06 PM
satan_srv's Avatar
Default Re: base parts for sh? compatibility question. (SuperSH)
Another reason why Honda Marketing is BS...given the profile change the SH should post higher flywheel power numbers, even if it does lose it at the wheels.
RACING INTEGRATION
Sep 5, 2005 05:00 PM
kitboi826
Jul 29, 2005 05:28 PM
micmasta
Sep 7, 2004 04:08 AM
hatchdrvr
Apr 30, 2002 06:47 AM
