Can i connect an amp to the bose system in the Type S?
hey guys,
the thing is i have this extra amp just lying around (mtx thunder280), and i was checking out the wiring to the bose amp, and it looks like it has batt, ground, left, right. So you think i could connect my amp to the stock bose system? you think the stock bose sub could handle it? Any info is koo. thanks
hey guys,
Bose amps/systems usually have a wierd impedience so your amp might not work with those loads, if it does, I doubt the speakers will be able to take it.
not sure about the car, but I know that the lifestyle subs run at a 1ohm load on about 25w rms. The bose systems are desgined to handle more but they don't get any louder.
don't bother trying it. the bose systems usually run 1ohm loads.
one of 3 things will happen:
1. you will burn the MTX amp up
2. you will cause problems with the stock system
3. or both 1 and 2
I wish car manufacturers would stop using bose systems they are just a pain in the ***.
hope u dont blow a speaker cause they are usually around 300-350/pair.
bose systems are a total waste of money IMO.
3. or both 1 and 2
imadigitalgod
Audio / Security / Video
18
May 13, 2008 04:00 PM
ilikeric3
30
Sep 2, 2006 02:21 PM
