4th gen, throttle body / intake manifold
Old Jan 12, 2003 | 07:20 PM
Stopher's Avatar
Default 4th gen, throttle body / intake manifold
i have a 91 EX (f22a1), and got a tb from an h22. the problem is that the tb didnt bolt up. naturally i think, just get an h22 manifold. but this raises the question, will it bolt up? thoughts? if i got a 5th gen vtec head would it bolt up to my current or an h22a intake manifold any ideas???
Old Jan 12, 2003 | 07:24 PM
Stopher's Avatar
Default Re: 4th gen, throttle body / intake manifold (Stopher)
by the way, i DID do a search.
Old Jan 13, 2003 | 10:43 AM
cyrixvsp2's Avatar
i don't know, i don't see why you would want to use an h manifold on an f series motor....you aren't going to get that great of performence increase for the cost and pain of doing it.
for your motor, the a1, i'd say find a 92-93 ex with an a6 in it, swap that intake and ecu out and that will bump you up to 140hp and it's a direct bolt on iwth no headaches. that's what i'm doing with my f22a4 to get that extra 5hp it has over my engine.
Old Jan 13, 2003 | 07:55 PM
ratherbewalking's Avatar
Default Re: 4th gen, throttle body / intake manifold (cyrixvsp2)
has anyone else had this problem with the h-series tb not matching up?
Old Jan 13, 2003 | 08:12 PM
Desslok's Avatar
Default Re: 4th gen, throttle body / intake manifold (ratherbewalking)
I have an H22 TB sitting in my garage, I've just been too lazy to try it. Maybe this weekend I'll give it a shot and let you know what I had to do to get it on.
Old Jan 13, 2003 | 08:31 PM
StimpyBoy's Avatar
cyrix, when you do it, I'd love to hear about it. I'm in pretty much the same boat (f22a1) and I've looked at maybe swapping on the 92-93 EX intake/ecu. I'd be interested to hear if you run into anything.
Old Jan 13, 2003 | 08:46 PM
d15dood's Avatar
cough cough search
Old Jan 14, 2003 | 07:12 PM
cyrixvsp2's Avatar
Default Re: 4th gen, throttle body / intake manifold (battlecat187)
probably going to happen soon for me so keep your eyes open. i might wait until it's warmer, and it depends if the army is letting me take a POV. If so then probably this spring. someone on teh board has done this already and gave me some tips so try a search to see if you can find that. there are some vaccuum changes you have to make, but other htan that it's direct swap.
Old Jan 14, 2003 | 08:35 PM
ArchAngel Sabastian's Avatar
New User
h22/23 TB direct bolt on too f22b1/b2 series IM's. ( no power gain unless plenum is ported)
most likely will not match to 4th/6th gen IM's
2kdrift
Sep 10, 2007 05:36 AM
tmrtwo
Apr 19, 2007 05:29 PM
afg69
Jan 18, 2007 07:03 AM
One2chi
Feb 27, 2003 11:19 PM
