removing pins out of ecu connector on 00 civic si?
can anyone explain to me the procedure to remove a pin out of the ecu plug? I know on the older plugs you just stick a small screwdriver or pin and push up but the newer plugs have that white stripe that comes out a little. Does anything need to be done with this? I just wanna be sure before i try. Thanks
i saw that post but im not sure if its the same procedure on the newer plugs...as you can see in the last post on that thread he states that the new plugs have the white strip..thats what mine have. Thanks for your help
what are you removing the plugs for??
Uzumymw
Nov 16, 2015 11:52 PM
