Oil leak!!!
Old Jan 12, 2003 | 03:47 PM
Cereal_Killer's Avatar
Default Oil leak!!!
well as i was checking fluids today i noticed my car was low on oil...about 1 qt. also i noticed some oil build up on my garage floor and droplets (fresh clean oil) formed on the tranny where the case and bell housing meet. upon further inspection i see where it "looks" like it might be coming from....axle seals! but what would explain the loss in engine oil. rear main seal? or is this signs of something worse?
Old Jan 12, 2003 | 04:06 PM
greebler's Avatar
Default Re: Oil leak!!! (hybrid_crx)
PCV valves? Head gasket, clean your engine bay and see where it comes out.
Old Jan 12, 2003 | 04:10 PM
Default Re: Oil leak!!! (greebler)
all those are clean no signs of leaks. only comes out from the bottom. only place it seems to be exiting from is tha axle seal or maybe flywheel area.
Old Jan 12, 2003 | 04:41 PM
couter.net's Avatar
oil can come from many place try and trace it
check the oil pan/ bolt
Old Jan 12, 2003 | 08:50 PM
jdmcivicek's Avatar
Default Re: Oil leak!!! (couter)
check your oil pan gasket. sounds similiar to my leak that ended up being the oil pan gasket.
Old Jan 13, 2003 | 07:26 AM
South sol's Avatar
Default Re: Oil leak!!! (jdmcivicek) I also have leaks
My leak is coming from axle seals, just swapped trannies so I can only assumed it is the seals so I ordered new ones from acura w8ing on them to come in!
My oil leak is coming from my pan, I 1st replaced the gasket now having to order pan from honda-- trying to get one on ebay though skeptical>
immalooser
Sep 25, 2009 08:05 AM
johnny_bighood
21
Jul 4, 2009 02:03 PM
Teglessb18
Oct 21, 2005 03:06 PM
overdose
Apr 27, 2003 02:03 PM
MeanGreenEG9
Jan 13, 2003 11:09 AM
