what tranny for ls turbo
Old Jan 12, 2003 | 02:50 PM
NightHawkC5's Avatar
Default what tranny for ls turbo
Whats a good tranny to go with on a FI LS running about 9 psi
[Modified by NightHawkC5, 11:50 PM 1/12/2003]
Old Jan 12, 2003 | 03:30 PM
BoM's Avatar
BoM
Default Re: what tranny for ls turbo (NightHawkC5)
Si with aftermarket LSD
or
Type R
if you raise the revlimit, it will be the fastest.
[Modified by BoM, 5:23 PM 1/14/2003]
Old Jan 12, 2003 | 03:39 PM
DIRep972's Avatar
Smarter than you
Default Re: what tranny for ls turbo (BoM)
or
Type R
ok no. LS' only rev to 7000 rpm's. 4th gear on a standard 205/50/15 tire w/ an SI tranny will only do 100mph at 7000. my ls turbo on 9psi trapped 105 so the Si/type R gears are already too short.
go with a gsr tranny.
Old Jan 12, 2003 | 04:11 PM
Default Re: what tranny for ls turbo (DIRep976)
So basically i should go with the ls tranny because of the longer gearing
Old Jan 12, 2003 | 04:12 PM
BoM's Avatar
BoM
he can always build the head and have a higher rev limit.
Old Jan 12, 2003 | 04:14 PM
DIRep972's Avatar
Smarter than you
ok no, this is the other extreme that is wrong as well. go for the best tranny for ur application. a stock motor LS turbo @ 9psi, the best tranny for that is defintly a gsr.
Old Jan 12, 2003 | 04:23 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Id go GSR....
Old Jan 12, 2003 | 04:46 PM
BoM's Avatar
BoM
Default Re: what tranny for ls turbo (SIXTYdashONE)
what about adding final gears?
to make the gearing shorter.
whats your setup DIRep?
stock LS gears?
Old Jan 12, 2003 | 05:21 PM
DIRep972's Avatar
Smarter than you
stock LS gears?
I run a stock LS tranny but i trap at around 110 now. its still too tall but a gsr is too short if i go above 300whp w/ out upgrading the head. i take it to 7500. if i could have a perfect tranny for my car right now it would either be an LS w/ gsr final or a gsr w/ LS final. us LS guys are kinda in a different situation when it comes to trannies cause we can only rev and make power to about 7300.
Old Jan 12, 2003 | 05:22 PM
boosted3g's Avatar
I agree B16A or itr trans and jsut rev it higher. All the guys here in PA know i revved my LS with a crower valvetrain to 9400 and made power all the way there.
Old Jan 12, 2003 | 06:21 PM
DIRep972's Avatar
Smarter than you
Default Re: what tranny for ls turbo (boosted3g)
what cams and what sized valves were u using making power to 9400?
Old Jan 12, 2003 | 06:31 PM
Mr. Softee's Avatar
with my gsr tranny i still had to go into 5th on drag radials.. made me mad.
Old Jan 12, 2003 | 06:52 PM
lazy bum shaughn's Avatar
Yes, I would like to know as well. I also want to know how an LS block would handle those revs.
How about an LS tranny with a JDM Type R final drive, just a thought?
Old Jan 12, 2003 | 08:29 PM
mamaboy's Avatar
wouldn't you want to keep an LS tranny with a boosted b18b for traction issues? just my .02. correct me if i'm wrong. i don't want to spread bad info
Old Jan 13, 2003 | 05:50 AM
Default Re: what tranny for ls turbo (mamaboy)
i guess the ls tranny with gsr final drive will work so that i would not have to go in 5th on a 1/4 run
Old Jan 13, 2003 | 07:08 AM
STHPERFORMANCE's Avatar
Josh was using 1mm oversized ferrea valves and crower 402's i beleave... I bought the top end off him but he had already sold the cams till i got the head...
Old Jan 13, 2003 | 08:21 AM
BudaKai's Avatar
Default Re: what tranny for ls turbo (Outkast)
Look here: http://ff-squad.com/GearRatios.htm IMO I'd use Ls and use smaller wheels with smaller tires. You'll have less unsprung weight that way so your acceleration would be greater than with a Gsr and larger wheels to keep traction. Unfortunately I'm stuck with a GSR and traction problems . I want to buy a cable LS because hydrolic is just extra weight I don't really need. That and there's no room in my dinky engine bay.
Old Jan 13, 2003 | 08:30 AM
MotorMatrix.com's Avatar
I am a bad person
or
Type R
Old Jan 13, 2003 | 08:40 AM
jinxproof99's Avatar
New User
Default Re: what tranny for ls turbo (MotorMatrix.com)
springs retainers and ecu remap, then go b16/type r.
Old Jan 13, 2003 | 10:59 AM
boosted3g's Avatar
Default Re: what tranny for ls turbo (jinxproof99)
i had Crower valve springs and retainers and 404 cams. The bottom end on the LS is not bad is the rocker arms. Later when i switched to my own custom grind i broke a few rocker arms but it was due to the aggresive cam lobes on the specs that I requested. I ordered those cams to get the rev range down but i did not help, hell i had a 208 duration with a .470 lift and the power band was still way too high. I had a SFP manifold with a 60-1 turbo and i just liked to rev. But i didnt like the 26 psi and the 120 shot of nitrous. Thats when the motor met a cruel end. I wouldnt let the r/s ratio fool you nor the fact that the LS head dont flow. I know several people who have had great reslts with the Ls or B20 motors including jinx who had a simle mid 13 second NA b20. Vtec is great but if you jsut dont have it you can comprimise in other ways to make power.
Old Jan 13, 2003 | 01:02 PM
Crxlsturbo's Avatar
Default no GSR or SI..
trust me you won't like the gearing on it. I had it on my 95 LS motor in my Crx and I was only boosting 7psi. 1st gear is a bitch and very quick. Even 2nd gear. Just stick with the LS tranny because later on in the future if you plan on running low 12's, high 11's you will need to ditch the GSR tranny and go with the LS one. Unless you have Head work done to make it rev higher.
Old Jan 13, 2003 | 01:07 PM
DIRep972's Avatar
Smarter than you
I agree, its all about the cams.
if u have the ability to rev it high of course go with the shorter gears, but for those of us like me, who go for the high boost on stock head approach, the short gears are just not a reality.
Old Jan 13, 2003 | 02:38 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Yes LS tranny is better for turbo because the gears are longer but the other tranny's maybe stranger. I would stick with ls or maybe GSR
Old Jan 13, 2003 | 02:40 PM
boosted3g's Avatar
Default Re: what tranny for ls turbo (HybridcivicLS-T)
The trannys are the same strength. The have the identical parts except for the 2nd or 3rd gear syncro in the vtec tannys. Even the case is identical.
Old Jan 13, 2003 | 04:15 PM
SupaTeg's Avatar
Default Re: no GSR or SI.. (Crxlsturbo)
This is the first post about "Which tranny is better for turbo" where you guys actually know what you are talking about. Shorter gearing is not for FORCE INDUCTION. Look at all the turbo trannies from Supra's, RX-7's,etc....... TALL gears!
