help please problem with my rex
i was trying to swap o2 sensors to make it run better, i cant figure out how to get pin 16 out, so i put the two clips back in the "c" plug
i left my house and now the cel is on
it flashes two long bars then 3 short dots (- - ...)
what code is this 23 or 3? and what does it mean
thanks for hte help
thanks for hte help
i don't think there is a code 23 for a crx. i believe it is 2 codes, 20, and 3.
http://tech.hybridgarage.com/tech/codes.html
There is no code 23, it sounds like you have code 20 and 3. Code 3 is the map sensor and code 20 is the Electric Load Detector. Thoughs are the 2 codes it sounds like you have.
idk if its the knock sensor.. it seems wierd that i was messing around with the c ecu clip and now this problem starts? do knock sensors go bad much?
also i noticed the b pin connector is a bit cracked, u think a bad connection can spawn this and
how u get pins out of b adn c???? i did a search and cant find much
thanks
electric load detector doenst exist of a b16a, remeber this pin is swapped for knock sensor (ironic huh?)
thanks
DBallz
Aug 29, 2003 05:56 PM
