... stock ls block and nitrous
Old Jan 12, 2003 | 10:31 AM
1.8T_EG's Avatar
Default ... stock ls block and nitrous
... what is the biggest shot of nitrous that i can get away with without blowing up my motor?... assume average to above average tuning... i have been told 80 shot... anyone else have any other thought?... lemme know... thanks...
Old Jan 12, 2003 | 10:39 AM
tuco_ruiz's Avatar
Default Re: ... stock ls block and nitrous (1.8T_EG)
i spray a 50 wet shot on stock block w/ various bolt ons. i wont spray more cuz i have an auto and i'll blow my tranny before the engine . but i've gone through alot of bottles and have had no problems.
Old Jan 12, 2003 | 11:16 AM
NX_LS's Avatar
If you don't mind spending the 100 bucks for a blockguard, a 100 shot could be run. Just make sure that your fuel solenoid is in good condition. The LS motor has a fairly decent fuel pump, so you should be fine in that respect. Unless your running an NX kit, I would suggest taking out 4 degrees of total timing (easy to do with a timing light). If your running an NX kit (the best kit on the market in my opinion) I would only take 2 degrees of timing out. Other than that you should be alright. Just watch that A/F ratio via an A/F Guage or an Exhaust Gas Temp (EGT) guage.
Happy spraying!
Old Jan 12, 2003 | 11:58 AM
integranator's Avatar
Default Re: ... stock ls block and nitrous (NX_LS)
I shall be running a direct port nx 100shot on my LS by spring time, i'm making sure i get stainless steel valves to make sure i don't burn em' up, other than that ignition, fuel pump is all i'm going to be getting. Good luck!
Old Jan 12, 2003 | 12:57 PM
NX_LS's Avatar
Default Re: ... stock ls block and nitrous (integranator)
All you need in terms of ignition are some good plugs (I recommend NGK V-Power plugs) and some good wires. Stock Honda ignition systems are very good.
Old Jan 12, 2003 | 01:30 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: ... stock ls block and nitrous (zetarider)
50 shot - with only colder plugs.
75 shot - colder plugs, ignition, wires, and timing.
sonne_side
Jan 5, 2009 12:03 PM
nitroaccord105
Jul 18, 2007 12:32 PM
WhiteLS
Sep 21, 2003 11:34 AM
integra2ner
Jan 6, 2003 09:54 PM
