What should I get, either Skunk2 manifold or a lightweight flywheel?
Old Jan 12, 2003 | 09:56 AM
Civichatch972's Avatar
Default What should I get, either Skunk2 manifold or a lightweight flywheel?
I have some money left over from getting my organic racing clutch and was thinking about getting a lightened fly wheel while getting my new clutch, but then I was thinking that I also wanted to get a skunk2 manifold,
I am not sure what I want to get?
What would help more out in perfomance?
And maybe should I get something else for around the same price
Need some advice?
Old Jan 12, 2003 | 10:01 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: What should I get, either Skunk2 manifold or a lightweight flywheel? (Civichatch972)
get the flywheel since your getting the clutch
Old Jan 12, 2003 | 10:34 AM
Default Re: What should I get, either Skunk2 manifold or a lightweight flywheel? (CiRcUiTsi)
yeah but wouldn't a skunk2 make more of a difference with mor HP and torque?
Old Jan 12, 2003 | 11:29 AM
poo flinger
Guest
Posts: n/a
Its a lot easier and saves you time if you put in a flywheel when swaping out a clutch. The intake manifold can always come later. Plus, without a set of bigger cams, you won't notice much gain for the manifold. It will just sound louder.
Old Jan 12, 2003 | 11:32 AM
lazy bum shaughn's Avatar
I'd get the flywheel since you're taking out the tranny out anways. You could get the manifold, but it would benefit with cams, pistons etc, and plus you'd have to get a new ECU to disable the butterflies...or whatever.
Old Jan 12, 2003 | 12:07 PM
Heath's Avatar
Default Re: What should I get, either Skunk2 manifold or a lightweight flywheel? (lazy bum shaughn)
Get the flywheel. It will save you time and money. My mechanic said the same thing....the manifold by itself won't do much.
Old Jan 12, 2003 | 02:54 PM
swrdply400mrelay's Avatar
Default Re: What should I get, either Skunk2 manifold or a lightweight flywheel? (95civicturbo)
Get the manifold later.
baynedo
Mid-Atlantic (Sales)
Jul 11, 2010 01:23 PM
djteggy99
Feb 27, 2009 08:05 AM
cycopath
Mar 24, 2008 07:59 AM
JT0220
Jun 24, 2005 05:05 PM
96_GSR
Aug 1, 2002 07:33 AM
