i am pissed
Old Jan 12, 2003 | 01:40 AM
whitemike1644's Avatar
Default i am pissed
haven't even had my car for 3 months yet and the ******* windows are fucked up.
the driver side or the passanger side don't roll down and yes they are manual windows niether side rolls up or down they just get stuck and start rolling up and down all fucked up i think the window thing is bent anyone else have this problem?
and if so how much and where can i get it fixed because honda they want just about 180 in labor alone and i aint tring to spend that much on my cars windows
Old Jan 12, 2003 | 01:42 AM
b18b-HB's Avatar
Default Re: i am pissed (whitemike1644)
shoot my passanger side does the same thing, I don't know how to fix it. help me also
Old Jan 12, 2003 | 01:45 AM
Grandma Humper's Avatar
hasent happened to me, but i know guys it has happened too....seems like the lower model civics have this problem in the cold... the window is off the rail..all u gottah do is take out your door panels and in the space where the speaker sits, theres a bracket u can remove and sit the window back in the rail, to avoid this in the future just dont roll your windows down all the way
Old Jan 12, 2003 | 09:21 AM
Default Re: i am pissed (gensix)
no i took off my panel and even with me like adjusting it while i was rolling it up and down it still won't work like it was fucked up either way i think the thing is bent some how because my driver side it hits the bar that goes across the side like incase of an accident.
Old Jan 12, 2003 | 09:28 AM
black2kcivic's Avatar
the same thing was happening to me so I got some honda spray silicone and sprayed the window seals really good with it and it fixed the problem right away.
it seems like something simple and stupid but it works.
[Modified by black2kcivic, 10:28 AM 1/12/2003]
Old Jan 12, 2003 | 07:45 PM
Did u put the window back in the rail??? if its hitting that bar, then i dont think the window is in the rail right..
Old Jan 12, 2003 | 07:57 PM
VTECVillain's Avatar
Not sure what the case is but if the window glass brackets are bent then you'll need to take them out and straighten them or replace them. It might be a problem that the window glass isn't aligned properly and it's coming off track. Either way, make sure not to get it in a bind because the tabs can break off the bottom of the glass easily.
CivicRaping
Nov 15, 2020 12:47 PM
billedoc
May 17, 2006 12:19 PM
KillerElfboy
Mar 29, 2006 05:15 PM
seer_claw
Jan 31, 2004 01:53 PM
SlammedHatch90
Jan 31, 2003 03:49 PM
