Check engine light comes on some times. But why ?
Today when I started the car, my check engine light comes on. I look at the ecu, and the light is just on, no flashing or anything. I'm like ok, it has done this before. So I shut the car off, turn it back on and everything is back to normal. So I let it run for about 10 minutes, and when I pull out of my drive way, I was trying to go really slow cause my parents were sleeping ( I did not want my car to rev to high or else its loud ) and I accidently stalled it. So I start the car up, and once again the same thing happens with the check engine light. So I shut it back off, and then started it and everything is fine. Both times the car ran fine while the check engine light was on, the first time the idal seemed high but that was because I had not started it in awhile. So what could it be, the only thing that has been different is it has been really cold out. Maybe its a bad ground some where.
[Modified by 90blackcrx, 1:24 AM 1/12/2003]
Teamdiesel
May 18, 2007 05:57 AM
