shaking steering wheel
Old Jan 11, 2003 | 06:28 PM
E dwinbon G's Avatar
Default shaking steering wheel
the steering wheel starts to shake when braking a little harder than normal what may be the cause of this? 90 accord
Old Jan 11, 2003 | 06:37 PM
Chiovnidca's Avatar
Default Re: shaking steering wheel (edwinbong)
Warped rotors is one possibility.
Old Jan 12, 2003 | 05:04 PM
HatchSteer's Avatar
Default Re: shaking steering wheel (Chiovnidca)
You brakes are wearing out. Restore them or get new ones.
Old Jan 12, 2003 | 06:55 PM
jdowen2's Avatar
Another possibility is a bad wheel bearing.
Old Jan 12, 2003 | 07:02 PM
JackAcc's Avatar
Sounds like warped rotors to me. I have had this happen on both my 94 and 95 accords. Sometimes they get a hard spot on them that will not be able to be machined correctly. Probably need to replace them. See if your local dealership will machine them. Might do the trick. Much cheaper... Good luck
Old Jan 12, 2003 | 11:04 PM
Default Re: shaking steering wheel (JackAcc)
thanks for the info
Ohbebe75
Oct 24, 2015 07:50 AM
TOO MUCH TORQUE
Aug 15, 2010 06:53 PM
jpopvriens
Jun 2, 2007 12:40 PM
teletekman
May 3, 2006 09:15 AM
redteg1
Apr 1, 2004 11:24 PM
