dead ecu?
I had the stock ECU fry itself, and it was replaced under warranty on my 2000 Prelude.
What symptoms are you seing? Is this the original ECU that came with the car?
Andrew
Andrew
Err... Why would you remove the Immobilzer unit?
I would assume that is why your car is not starting. I can't find the link to the arcticle about the Prelude's Immobilzer anymore. But IIRC, the ECU needs the immobilzer signal in order for it to allow the car to crank.
You can't just say, "My car won't start. Is the ECU dead?" A better description of your symptoms would get you a lot more input on this... i.e.: Is the car cranking? Is it cranking, but not firing? Is it trying to start, but stalling? etc.
Andrew
I would assume that is why your car is not starting. I can't find the link to the arcticle about the Prelude's Immobilzer anymore. But IIRC, the ECU needs the immobilzer signal in order for it to allow the car to crank.You can't just say, "My car won't start. Is the ECU dead?" A better description of your symptoms would get you a lot more input on this... i.e.: Is the car cranking? Is it cranking, but not firing? Is it trying to start, but stalling? etc.
Andrew
Yes, the ECM needs the Immob signal to fire up the fuel system and ignition setups. Otherwise, it either won't crank at all, or will crank but only run for 2 seconds. If you want to do away with the immob you'd have to get a new ECM and (not sure on this part) but i bet you'd have to rewire quite a few relays and such so they kick on W/O the immob's signal
Hey, I have a JDM 5th gen Type S ECU for sale that does not require the immobilizer. It also has slightly more aggressive timing and fuel curves. Email me at davidrierson@attbi.com if you are interested.
David, I was under the impression that the Japanese TypeS ECU does have the immobilizer functionality... When Nam D Vo did that ECU swap in like 1999, he had to go to a Honda dealer to get it reprogrammed just like a US ECU. He said it would not start otherwise...
Andrew
Andrew
also, if it's not vtec will it still work on my sh? what's type s? i'm kinda new at this so please excuse me.
i would like some information on it like is it vtec, manual trans, obd?, p??, etc. thanks.
The TypeS Prelude is the 217hp Prelude version sold in Japan. It is the only other Prelude with the ATTS.
Andrew
this is one question i've been thinking about since this post... is there any extra wiring you have to do to actually get the P72 to work in a 97+ prelude (besides the OBD-II -> OBD-I cable) because of the Immobilizer? The OBD-II ecu has the function controls that turn the fuel pump on and off when the correct key is put in, but would these same routines need to be mimiked for the pump to come on with the OBD-II, or is it one of those the ECU only shuts it off if the wrong key is put in?
damn, i got the type S ecu but it's still not starting
. this car will never start!
hey aklucsarits, think i can get the same information about whether or not you'd have to rewire anything if you go obd2-1 harness and p72/p13 ? thanks.
. this car will never start! hey aklucsarits, think i can get the same information about whether or not you'd have to rewire anything if you go obd2-1 harness and p72/p13 ? thanks.
Jet Black
May 13, 2004 08:17 AM
