which pin on the P28 ecu is the vtec wire
Old Jan 11, 2003 | 10:47 AM
crazydude75927's Avatar
Default which pin on the P28 ecu is the vtec wire
just as i said i realy need to find out which wire is the vtec selonoid wire it would realy help if i knew this by the end of today thanx if you know please e-mail me at crazydude75927@yahoo.com
Old Jan 11, 2003 | 07:39 PM
AztecRacer's Avatar
Default Re: which pin on the P28 ecu is the vtec wire (crazydude75927)
Green / White wire off of the A4 block on a p28 computer. Good Luck
Old Jan 11, 2003 | 08:07 PM
smnowell's Avatar
Default Re: which pin on the P28 ecu is the vtec wire (AztecRacer)
partly right. The wire is green/yellow coming off of the VTEC solenoid. Once it passes through the main connector where your engine harness meets the main wiring harness it turns to Orange/White VTEC Solenoid is A4 on your ECU.
Old Jan 11, 2003 | 08:08 PM
smnowell's Avatar
Default Re: which pin on the P28 ecu is the vtec wire (b16a ferio)
here, use this page as a good reference
http://tech.hybridgarage.com/tech/5gtech/index.html
jdmdomi90
Dec 5, 2011 05:28 PM
civicb16limegreen
Oct 2, 2005 01:58 PM
turbotime
Jun 8, 2003 09:15 AM
BluntMan
Jan 3, 2003 09:23 AM
