lowering 4th gen??? need some serious help!!!
Old Jan 11, 2003 | 09:24 AM
Superdragr45's Avatar
Default lowering 4th gen??? need some serious help!!!
the last 4th accord i had was lowered 2 in. and after i had a camber kit installed, the a-arms would bash the fender well. on my next accord, i want to lower it the same as last time, but, would removing the inner fender after installing the camber kit help at all?? any advice will be helpful
Old Jan 11, 2003 | 03:52 PM
cyrixvsp2's Avatar
Default Re: lowering 4th gen??? need some serious help!!! (Superdragr45)
hmm....that's very odd, i've never heard of the a-arms hitting the fenders with that drop, and i know guys that lay their cars out....so 2" shouldn't do that.
i would'nt worry about a camber kit for 2" drop, just have it re-aligned so your toe-in isn't out of wack and you should be good on tires.
Old Jan 11, 2003 | 04:06 PM
Default Re: lowering 4th gen??? need some serious help!!! (cyrixvsp2)
some people told me that the camber kit pushed the arms out and thats why they were hitting. soo i should just leave the inner fendr in??
Old Jan 11, 2003 | 07:15 PM
patastinky's Avatar
yeah the camber kit will push it out a bit.. i got a 3.25 drop but i shaved the control arm a bit and the inner fender now i dont have that problem any more
Old Jan 11, 2003 | 07:25 PM
f22a's Avatar
Default Re: lowering 4th gen??? need some serious help!!! (patastinky)
pata, it appears that we have both retreated here after hs being down for maintenance?
but i am with pata and am lowered 3.25 as well, and my control arms knock like sons of bitches. its horrible. i tried to shave off a bit of the control arm and it didn't do a thing, it is knocking the top of the fenderwell in there. shaving off the end will make it clear that little lip in there. i think i may buy some yellows or agx and stiffen it up in there and see if that helps with the knocking. other than 1) stiffening it up in there and 2) cutting out where it knocks, i dont have a clue.
Old Jan 11, 2003 | 07:36 PM
patastinky's Avatar
Default Re: lowering 4th gen??? need some serious help!!! (f22a)
yeah bro, i feel you i am on another board that has a 4th gen forum like HS
http://importstreetscenes.com/tech/f...6173&forumid=9
click there on the link there cool ppls there, just started.. lots' of 5th gen HS ppls on the boards there on the 5th gen forum
f22a,, ur **** is still ******* hitting i got the ingalls camber kit and my **** dont knock how much did you shave off i didnt shave that much off the control arm, but i sanded down the inner fender some too bascially i shaved then dropped it (lowerd the jack) the popped the hood and put my feet on frame that goes over the headlights and jumped up and down to make usre my **** wasnt hitting.. i did that till there was no more knocking bro ... if u need help hit me up on aim "pscyberpimp"
get koni yellow.. agx arent recommend for our drop... (thought u got ur yellows already *Shrugs*)
Old Jan 11, 2003 | 08:54 PM
scrubachu's Avatar
i have my 4th gen w/h22 lowered 2", and 2.25" and it doesnt hit anything. no knock or banging from the control arms. ive never had a problem. you sure its just a 2" drop?
aries331
Jan 4, 2008 07:46 PM
1991EX
Suspension & Brakes
Sep 30, 2007 07:43 PM
JDM_EjONE
Jul 18, 2007 05:51 PM
masteryoda10
Mar 19, 2006 07:18 PM
4DRPIMPIN
May 6, 2005 12:09 PM
