Heat Shielding for my CF hood? DSM's have it stock......
Old Jan 11, 2003 | 09:10 AM
Firedrake's Avatar
Default Heat Shielding for my CF hood? DSM's have it stock......
Heya everyone....
I'm looking for something I can use to shield the heat from my carbon fiber hood.....DSM's have some kind of stuff under the hood stock, I'm wondering where I can get something like that? Or do I even need to worry (will carbon fiber stand up to the heat from the turbo?).....what are you guys and gals using?
Thanks!!!!
Brian
Old Jan 11, 2003 | 11:48 AM
BodyKits NW's Avatar
Default Re: Heat Shielding for my CF hood? DSM's have it stock...... (Firedrake)
The CF should be able to withstand the temp. The resin and gel coat we use is rated for 5,000 degree temp. I run a CF hood on my car without any problems. Also my hood is vented. I did have a OEM one in the past and that held up fine. I am not sure what kind of hood you have, but if good quality materials are being used then great.
Old Jan 11, 2003 | 02:31 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Heat Shielding for my CF hood? DSM's have it stock...... (BodyKits NW)
i think my cf hood is being affected by heat. I live in AZ during the summer and i noticed that the resin isn't that smooth any more. It's nothing too noticeable unless you're me. It's a fiber images hood. it's not engine bay heat because i only have bolt ons right now.
Old Jan 12, 2003 | 10:59 AM
Firedrake's Avatar
Default Re: Heat Shielding for my CF hood? DSM's have it stock...... (PreIudeSI)
TTT
It's a VIS Extreme GT style hood.......so you think it'll take the turbo heat fine? There are 2 big vents right above the front of the valve cover, so those should help too I'd think?
Thanks!!!
Brian
Old Jan 12, 2003 | 03:01 PM
Blaze45's Avatar
Brrraaaap!
you konw why your hood seems not quite the same in the summer? black attracts the sun and the sun makes things VERY hot.
Blaze
Thateguhate
Nov 16, 2007 03:59 PM
Jamied
13
Jan 28, 2007 06:01 PM
Black R
Jan 20, 2005 09:30 AM
succdeez
Oct 21, 2004 05:34 PM
Dr Pooface
Sep 27, 2002 07:06 PM
