Compression test on 98 GSR...have questions!
A guy I know has 240-241 all on 4 cylinders of his 98 GSR. He had teh head shaved some and did some chamber work. He claims he has like 12.5:1 compression now??!! Is this possible from just a regular compression test? Let me know! Thanks!
Those testers vary fairly wildly. I have 2 and one is always 20psi higher than the other. The purpose of the compression test is merely to look for variance from one cylinder to another. Unless you get a reading below 100ish on a new B18C1 I'd not worry too much about the actual #s unless they vary wildly across the engine.
