ITR cams in a base?
Old Jan 11, 2003 | 07:24 AM
ArticBlue03TypeS's Avatar
Default ITR cams in a base?
How much gain do you think I would get with itr cams in the k20A3? anyone know
Old Jan 13, 2003 | 03:00 AM
xHitxQuitx's Avatar
Default Re: ITR cams in a base? (eternalbluersx)
not sure if it will work b/c the base only has VTEC on the intake side, not exhaust.
Old Jan 13, 2003 | 08:57 PM
oldB18EF's Avatar
Default Re: ITR cams in a base? (xHitxQuitx)
yup, you might need the valves and K20A ECU or an ECU upgrade from Hondata because the stock ECU wont engage the exhaust side
Old Jan 13, 2003 | 10:16 PM
oldB18EF's Avatar
Default Re: ITR cams in a base? (efzero.com)
.shakes head.
the answers to this thread are so wrong.
and the right ones would be? putting the DC5R cams wont see much of a gain- stock rev limit is 6800 where the DC5R cams make power all the way to 8400- you wouldnt even be using them to potential without the ECU upgrade. Its a well known fact the A3 head does not flow as well as the A2/A- ive heard the valves/spring combo in the A2/A are the same so youd need those as well.
Maybe you should read up:
http://www.hondata.com/techk20general.html
[Modified by WR93EG, 2:17 AM 1/14/2003]
Old Jan 18, 2003 | 07:55 PM
Barknuts88's Avatar
Where do they sell these cams at? The ones made for the Si.
Old Jan 19, 2003 | 06:15 PM
Barknuts88's Avatar
I could not find any info on these cams at all. If you can tell me where you found this info I would appreciate it.
chb93
Jul 2, 2009 08:28 AM
motormike40
Dec 26, 2007 10:21 AM
DA-9mordef
Apr 27, 2006 10:04 AM
yellowbuffalo
Jun 16, 2002 07:43 AM
95vtec
Sep 30, 2001 11:13 AM
