Want to Buy Want to Trade/Want to Buy
WTB: 99-00 Civic Si rear LCA's
Old Jan 11, 2003 | 01:20 AM
IDriveHonda's Avatar
Default WTB: 99-00 Civic Si rear LCA's
I am looking for a set of rear LCA's off of a 99-00 Si so I can put GSR brakes on my 99 hatch. Also interested in SSR LCA's if someone is trying to get rid of some. Hit me up.
Old Jan 11, 2003 | 03:28 AM
inspyral's Avatar
Default Re: WTB: 99-00 Civic Si rear LCA's (IDriveHonda)
Um, I'm not sure if you know this, but all 6th gen rear LCA's are the same. You don't need Si rear LCA's to use GSR rear discs. Your LCA's will bolt up the the GSR trailing arms just fine.
Old Jan 11, 2003 | 12:16 PM
Default Re: WTB: 99-00 Civic Si rear LCA's (inspyral)
Thats what I thought, I read another post that said otherwise, Thanks for the correction, but I could use the for an ITR swaybar install I guess. thanks. Do you or anyone else know where I could find some red billet LCA's? Like the SSR's.
[Modified by IDriveHonda, 3:17 PM 1/11/2003]
Old Jan 11, 2003 | 03:02 PM
inspyral's Avatar
Your existing LCA's should have holes int hem for swaybar endlinks. If not, I have some EX ones from my car that have the holes. They were swapped out when I got my SRR's. The SRR's only come in purple, I believe , but I think SPC makes them in different colors. Check the Best Buys forum.
Old Jan 18, 2003 | 03:55 PM
EricUSC's Avatar
Man, I'm getting confused now. Some people say the rear LCAs are the same and some say they are different. According to http://www.hondaautomotiveparts.com, the Si rear LCAs have different part numbers, but they cost the same as the rear LCAs from other Civics.
Old Jan 18, 2003 | 04:47 PM
inspyral's Avatar
Default Re: WTB: 99-00 Civic Si rear LCA's (EricUSC)
Actually, I just looked at Si LCA's and CX LCA's on Majestic's site, and they use the same part number: 22754. They're exactly the same. Left and right rear LCA's are also identical.
Old Jan 18, 2003 | 05:34 PM
EricUSC's Avatar
Your right. Just checked again and the rear LCAs are the same. The front LCAs and the forks do have different part numbers. Thanks for clearing things up.
Old Jan 18, 2003 | 06:36 PM
inspyral's Avatar
Yes, the fronts are different because the Si front LCAs are stamped aluminum instead of cast iron for weight reduction. Also, the Si front swaybar endlinks and strut forks mount differently than the EX ones so those mounting points are also different. The front LCAs on 6th gen Civics that don't come with a front swaybar are also different from the EX and Si LCAs.
Wazup
Jun 24, 2006 11:48 AM
miahmouse
Feb 18, 2004 10:33 AM
plan B.
Sep 30, 2003 09:36 PM
ichibano
Jan 16, 2003 02:51 PM
Pravo2
Jan 24, 2002 06:47 AM
