clutch not engaging...need help
Old Jan 11, 2003 | 12:12 AM
unidextrous's Avatar
Default clutch not engaging...need help
Car: 92 Civic Si
B20vtec/b16 tranny
My car was sitting for 3 weeks becasue of a broken axle. This was the only problem. I finally replaced it this week, and thoguht eveything would be okay. I start her up, put her in 1st, and let the clutch out. Nothing happened. I go to check my fluids and everything is okay. I then proceed to check the clutch master cylinder. A leak was obvious around the boot. I get a replacement and bleed out the line, but the clutch still does not engage? Could it be the slave cylinder? What else could be wrong? I highly doubt it's my clutch becasue it was fine before I snapped my axle.
thanks for any help.
Old Jan 11, 2003 | 12:37 AM
paulzy's Avatar
Default Re: clutch not engaging...need help (unidextrous)
is your slave cylnider arm moving in and out?
Old Jan 11, 2003 | 02:48 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: clutch not engaging...need help (1320development)
probably slave cly.
itr1244
Oct 30, 2008 04:25 PM
T Rick
Aug 23, 2007 06:28 PM
JThrasher79
Mar 29, 2006 07:48 PM
Komakazi_830
Dec 5, 2005 04:53 PM
JERKthisDC2
Nov 11, 2005 07:51 PM
