Install on 1991 Acura Legend
Old Jan 10, 2003 | 10:07 PM
greyzone's Avatar
Default Install on 1991 Acura Legend
Im helpping a buddy do an install on his wifes 1991 Acura Legend this SUnday, any thing wierd or difficult about this intall that anyone knows of??
Doing a simple deck with four new speakers, no amps...probably just solder in quick connect to back of deck and plug into factory harness using stock wires...not talking about something expensive.
Thakns
Old Jan 10, 2003 | 11:15 PM
philly-O's Avatar
Default Re: Install on 1991 Acura Legend (greyzone)
the deck can be a little tricky to get out but be patient and you will be fine, cause it is held in with screws instead of 8mm bolts like in hondas. in the past i have found the door pannels somewhat flimsy especially if they have been removed before. goodluck!
Old Jan 11, 2003 | 06:49 AM
greyzone's Avatar
Default Re: Install on 1991 Acura Legend (peichie)
thanks for the help!
Old Jan 11, 2003 | 09:28 AM
Desslok's Avatar
Does it have Bose system?
Old Jan 11, 2003 | 06:24 PM
greyzone's Avatar
Default Re: Install on 1991 Acura Legend (sp)
dont know, what if it does?
Old Jan 11, 2003 | 06:49 PM
gogeeta13's Avatar
i think the bose system had auxilary amps if IIRC. If that is the case, you will need to either:
A) Run new wires to the speakers
or
B) Find the amps, and just jumper around it.
Old Jan 11, 2003 | 08:50 PM
kwhitelaw's Avatar
Default Re: Install on 1991 Acura Legend (gogeeta13)
Pull the back seat. The bose amp is on the driver side. You can match the inputs to the amp behind the radio and jump them over to the outputs at the amp. Rear speaker grilles pop up. Easy. Front speakers require pulling the panel. It is a pain to get the top edge of the panel off. Slide a flat blade screwdriver, or panel popper if you have one, under the edge towards the rear of the door and smack the handle upwards to pop it free. Other than that, pretty easy car.
nicayotte
Honda Civic (2006 - 2015)
12
Sep 18, 2008 06:35 AM
CrazyModGSR
Audio / Security / Video
Feb 10, 2008 01:53 PM
raylude
10
Jan 21, 2007 12:26 PM
playboyace35
Sep 23, 2006 03:58 PM
Trooper
Feb 20, 2004 05:43 PM
