b16a or b16a w/ type R head???
Old Jan 10, 2003 | 05:29 PM
MoNkEyNutZ's Avatar
Default b16a or b16a w/ type R head???
sup all. right now i got a jdm second gen b16 with itr cams, toda cam gears, ls hydro tranny, act 6 puck, itr flywheel, and a mugen p28 chipped ecu, with skunk 2 full exhaust running in a 99-00 coupe. just wanted to know eta at the track and also if i throw on a full itr head will it make that much more of a difference and if its worth it. or
Old Jan 10, 2003 | 05:38 PM
rodrez.'s Avatar
Default Re: b16a or b16a w/ type R head??? (MoNkEyNutZ)
Depends on what it costs you? With your current set up, the only difference would be the port work and the valvesprings/retainers. If it's going to cost less to have portwork and valvetrain upgrades done, you might consider keeping what you have. As far as your track times, I couldn't say, EVERY car/driver is different.
Old Jan 10, 2003 | 05:45 PM
Chris y0!'s Avatar
Default Re: b16a or b16a w/ type R head??? (rodrez)
i'd say you run anywhere from mid 15s to low 16s.
Old Jan 10, 2003 | 06:13 PM
Dr. EKology's Avatar
If you really want to improve your times, ditch the tranny and get the JDM tranny w/ LSD!
P.S. How do you like that Skunk exhaust? How does it sound?
Old Jan 10, 2003 | 06:21 PM
KillerTofu's Avatar
or you could save some money and slap that b16 head on an LS....well whatever floats your boat.
Old Jan 10, 2003 | 06:29 PM
gamby's Avatar
Default Re: b16a or b16a w/ type R head??? (uncivical)
The LS tranny is what's throwing me off. W/ a B16 tranny, I 'd think you'd be able to eek out a 14.9 without much fanfare. Take acouple of tenths off w/ the ITR head.
This is all assuming you start w/ a healthy, 170 hp motor. All it takes is about 155whp to be a consistent 14.9 in a coupe.
Old Jan 11, 2003 | 01:36 PM
MoNkEyNutZ's Avatar
the only reason why im staying with the ls tranny is b/c im planning on goin boost after i build the motor. if i wasnt i would deffinetly go with a jdm itr tranny.
Old Jan 13, 2003 | 01:44 AM
MoNkEyNutZ's Avatar
anybody else got advice?
Old Mar 13, 2003 | 08:52 PM
Red CiViC Hatch's Avatar
high 15's low 16's???????????? u can do low 15's high 14's on a stock b16......i did
Old Mar 13, 2003 | 10:46 PM
jdmDXrex's Avatar
even with boost you can still run a vtec(gsr, b16, type r) tranny unless you plan on some crazy *** boost that you will be finishing at some high trap speeds.... 125+ which would mean you would be going at least 135mph real speed. but yeah thats just what i know.
i have a friend with a 96+ hatch with a Rev hard T304E boosting 12lbs on a stock bore gsr motor with 9.0:1 comp ported head. Still runs a b16 tranny with quiafe LSD runs 11.71@120 and hes not complaining. he ran an LS tranny before and he didnt like it but to each his own i guess..........
miamiboy91
Jan 9, 2009 05:24 AM
cacahead1
Aug 14, 2005 08:31 PM
shipsaeki
Sep 12, 2003 01:43 PM
civicdragger818
26
Nov 20, 2002 11:47 AM
Jaysmy
Jun 27, 2002 05:13 PM
