tires on EP3, will 205 fit the stock 16x6 wheels?
I've got a set of newer Toyos that are a 205 size and was wondering if anyone had tried this size on the stock wheel. It should fit, but I was just wondering.
Stock wheel is 15x6.
And any 205 should fit the stock wheel ok, as long as it isn't a 205/75 or something. if you go 205/50/15, then the tire will be shorter than the stock 195/60/15. This will affect gearing.
I run 205/50-15 Falken Azenis on my '00 Si 15x6 wheels. Azenis are much wider than "real" 205s, I believe they're just under 220mm wide. They fit no problem.
