which pin is the fuel pump on the 96-99 ecu?
Old Jan 10, 2003 | 05:29 AM
joblow's Avatar
Default which pin is the fuel pump on the 96-99 ecu?
hey guys. i searched all over and can't find the damn pinouts diagram. i need to know which pinouts are the fuel pump on the obd2 ecu for 97-99. it's not getting any fuel after removing the immobilizer on my 97. i have the pinouts diagram for the 00+ but they're not the same.
Old Jan 10, 2003 | 06:12 AM
satan_srv's Avatar
Default Re: which pin is the fuel pump on the 96-99 ecu? (joblow)
A16 Fuel Pump Relay
Isn't the fuel pump not working cause you have no immobilizer?
Old Jan 10, 2003 | 07:36 AM
joblow's Avatar
Default Re: which pin is the fuel pump on the 96-99 ecu? (satan_srv)
A16 Fuel Pump Relay
what color wire goes there? (a16)
well, we took the immobilizer off and then swapped the a15 pin to the a16 pin on the plug and supposedly that should do it. but it didn't. then i found out that the pins on my plug is in the different position than the pins on the diagram of the pinouts for 96-98 civics/integras that we went by. now i'm trying to find the exact position my fuel pump lies in the plug.
96-98 civic/integra
my 97 prelude plug
Old Jan 10, 2003 | 08:29 AM
satan_srv's Avatar
From what I have it says the fuel pump is green/orange is A16.
A15 is the EVAP Purge control solenoid. it should be red yellow...
The wore you are pointing to is A20 ICM
By the way the Code signal for the Immobilizer is C22
boosted k20
Engine Management and Tuning
Feb 9, 2009 09:15 AM
GsrTurboCRX88
Nov 22, 2006 07:41 PM
o2flow.net
Oct 1, 2006 08:55 AM
MAUCH3
Apr 29, 2004 01:50 AM
