loud bang from exhaust
Old Jan 10, 2003 | 05:17 AM
roydogg's Avatar
Default loud bang from exhaust
Why is my car makin this loud poppin noise when I let off the throttle. Sounds like a fire cracker comin from my exhaust. Could my timing be off?
Old Jan 10, 2003 | 05:43 AM
samagon's Avatar
Default Re: loud bang from exhaust (roydogg)
backfire. this is due to there being too much fuel after you let off the throttle, not all of it gets burned in the combustion chamber and it continues to burn once the cylinder is on the exhaust stroke.
consider a new O2 sensor, and reset your comp.
after a while of doing it a lot it could damage your exhaust valves and catalytic converter.
Old Jan 10, 2003 | 06:52 AM
gsr96's Avatar
Default Re: loud bang from exhaust (samagon)
Or, it will also make a popping noise if you have a hole in your exhaust pipe. I've had that problem before.
Old Jan 10, 2003 | 10:50 AM
speedyed's Avatar
Default Re: loud bang from exhaust (gsr96)
I am having this same problem myself and just realized that there are some corroded holes on both tailpipe inlets. I will also upgrade to some MSD 8.5mm wires to help burn more effeciently.
Old Jan 10, 2003 | 03:05 PM
SonicBlueTeg's Avatar
yeps.. same here.. i have a lil crack/leak developing on my bpiping that pops at about 2500rpm after i let off the throttle.. it would also pop when i had a hole in my canister..
Old Jan 10, 2003 | 07:33 PM
mugenracer's Avatar
Default Re: loud bang from exhaust (SonicBlueTeg)
I had the same problem on a Sir CRX i had a few years ago, but it was caused by the fact that i had a straight 2.5" pipe from the manifold back to the muffler and it farted on decelleration every time!
Old Jan 10, 2003 | 09:15 PM
roydogg's Avatar
Default Re: loud bang from exhaust (mugenracer)
IT 's been doin it since I put my carsound cat on but not all the time. The cat went so I gutted the cat and now it's poppin everytime it hit's 3000 rpms during decelleration. So I should change my O2 sensor and upgrade wires and that should solve my problem?
Old Jan 17, 2003 | 11:02 AM
roydogg's Avatar
I've noticed low poppin noises during idle too.What can that be from? are my exhaust valves fucked?
Old Jan 17, 2003 | 11:23 AM
94civicx's Avatar
New User
I have that same popping noise as everyone else. It only started after I installed a test pipe.
Old Jan 17, 2003 | 12:07 PM
fiebru1119's Avatar
Default Re: loud bang from exhaust (94civicx)
my DC cat-back does the same thing around 2500-3000 when decellerating.. as far as I knew my valves were good
AguaFina_FB6
Honda Civic (2006 - 2015)
Apr 28, 2016 07:17 PM
f22a1 ftw
Jun 9, 2011 07:07 PM
cash2435
Aug 27, 2009 05:13 PM
