whats the quickest that a Honda has run on STREET tires??
Old Jan 9, 2003 | 11:12 PM
turbohf's Avatar
Default whats the quickest that a Honda has run on STREET tires??
was just thinking about this and have never heard of someone running 10's or anything on street tires. i did once see a turbo CRX with 18inch Volks run a 13.3...
anyway so whats the quickest a Honda has run on STREET tires or drag radials, DOT approved....oh and FWD
Old Jan 9, 2003 | 11:31 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: whats the quickest that a Honda has run on STREET tires?? (turbohf)
I ran 12.4@126 and i wasnt even trying. Not to sound cocky or anything. I just put a brand new ITR tranny in and didnt want to kill it. I just granny shifted it until top of second. i got raped out of the hole by a single cam. check out the video >>>
http://www.motormatrix.com/19lbs555r.mpg
Old Jan 9, 2003 | 11:37 PM
turbohf's Avatar
Default Re: whats the quickest that a Honda has run on STREET tires?? (MotorMatrix.com)
just got DSL love the quick download...
nice. that was on Nittos?
Old Jan 9, 2003 | 11:39 PM
I am a bad person
yes 555r's
Old Jan 10, 2003 | 03:21 AM
D-Man's Avatar
The Quickest is 9psihybrid on this board.He ran a 11.88@126 on bfg drag radials.
[Modified by D-Man, 7:22 AM 1/10/2003]
Old Jan 10, 2003 | 03:43 AM
AussieK24's Avatar
Default Re: whats the quickest that a Honda has run on STREET tires?? (D-Man)
Any idea what his 60 was on that run???
Old Jan 10, 2003 | 07:34 AM
gsrt's Avatar
how much did you boost? how many psi for tires?
Old Jan 10, 2003 | 08:40 AM
jinxproof99's Avatar
New User
Default Re: whats the quickest that a Honda has run on STREET tires?? (gsrt)
high 11's with a real street tire and real street car(no wheelie bars, full glass, pump/race gas)
.......and thats pushing it.
Old Jan 10, 2003 | 09:38 AM
D-Man's Avatar
Default Re: whats the quickest that a Honda has run on STREET tires?? (b16a4me)
Here ya go..... https://honda-tech.com/zerothread?id=304883
Old Jan 10, 2003 | 12:03 PM
I am a bad person
my run was on 19psi of boost and 15lbs of pressure in the tires. by the way my 60ft was a 2.5. once i get the tranny with the quaife ill be going for low 11's. i'll be running 26 psi and should be able to pull a 2.0 60ft.
Old Jan 10, 2003 | 07:33 PM
J2turbo21's Avatar
[QUOTE]I ran 12.4@126 and i wasnt even trying. Not to sound cocky or anything. I just put a brand new ITR tranny in and didnt want to kill it. I just granny shifted it until top of second. i got raped out of the hole by a single cam. check out the video [QUOTE]
128pmh bitch hahah i like that.Sounds like nitto 555r's can do the job.Tell me if this is a deal.205/45/15 $105/ea shipped.
Old Jan 10, 2003 | 08:43 PM
D-Man's Avatar
Default Re: whats the quickest that a Honda has run on STREET tires?? (J2turbo21)
12.4@126 vs 11.8@126..sounds like BFGs do the job better
Old Jan 10, 2003 | 09:13 PM
J2turbo21's Avatar
HEHE yea that does sound better.Man i need to get some tires.It will be either of those.
Old Jan 10, 2003 | 09:28 PM
I am a bad person
did you watch the video?? i wasnt attempting to run a good 60ft. i was just looking to see what mph i would get. my 555r's will out hook whatever bf tire the 11.8 car was running for only one reason. i was running 245/50/16's i had to notch the bumper to make them fit and they work!! i doubt the bf's were near that size.
Old Jan 10, 2003 | 10:02 PM
D-Man's Avatar
no,not yet,itll take to long at -56k
i would hope so,they were alot smaller..205/50R15s....but so far,your 555s havnt out hooked them,when it does run better than 11.8 then ill believe that
Old Jan 10, 2003 | 10:07 PM
I am a bad person
Good point I'll be sure to post once i get the new tranny in and make some passes.
Old Jan 10, 2003 | 10:11 PM
D-Man's Avatar
Old Jan 11, 2003 | 10:49 AM
DIRep972's Avatar
Smarter than you
actually, robby(9psihybrid) cut a 1.9 60ft on that run w/ the bfg's. and they were 225/50/15 not 205. you should be able to do the same considering u have a wider taller tire but size for size bfg's will out hook the nitto's again and again.
Old Jan 11, 2003 | 10:59 AM
New User
Default Re: whats the quickest that a Honda has run on STREET tires?? (DIRep974)
couple of things:
the bfg's are much better than the nitto's, especially the 225's.
running a big t3/4 hybrid(60-1) or a ball bearing t4 60-1 is going to net better times than a larger turbo, such as what i had, a 62-1. when that thing hit full boost, it was rediculous. i have hit 60's in the 1.90's on t3/4's, but with my 62-1 i was running like 2.20 60's. had to really be careful out of the hole, or it was "spin city". big time. lol.
there are better tires out there. not daily drivable in my opinion, but still legal radials for weekend racing/street racing. american racing makes a 26x8" radial you can use on turbo hondas.
2 step boost controller is a must. preferably you have a small wastegate spring, not a 1 bar spring like i had. get out of the hole @ about 8 lbs, and in top of 2nd or in third, depending on your set up/tire, hit high boost.
traction bars, bushings, correct camber/alighnment are also a must for the best launch, street tire or slick.
Old Jan 11, 2003 | 11:08 AM
DIRep972's Avatar
Smarter than you
Default Re: whats the quickest that a Honda has run on STREET tires?? (jinxproof99)
I believe M/T makes a ET street in 26x8x15 that can work on our cars. that is a HUGE tire though, much too big for most of us out there. I think someone needs to come out w/ a 24x8x15 ET street, I would run it and im sure tons of others would too. anyone think making a petition with tons of names on it would make a tire company consider making this sized tire?
Old Jan 11, 2003 | 11:13 AM
New User
the american racing tire is better for imports. it has a decent sidewall, but its not as much of a "slick" as the et street. if you have say, 350+ hsp, then the american racing tire would be your choice for drivability and performance.
Old Jan 11, 2003 | 12:13 PM
D-Man's Avatar
No,it was the 205s,click on the link i posted above,he says what size he was using at the time of the 11.8 pass.
Old Jan 11, 2003 | 03:43 PM
DIRep972's Avatar
Smarter than you
umm, No. i qouted this from the link u posted. "I added a full exhaust and muffler and switched to 225/50/15 BFG G-Forces from 205/50/15"
Old Jan 11, 2003 | 09:59 PM
D-Man's Avatar
lol...OMG i must be reading it japanese style..from right to left sorry your 100% correct...225s..my mistake.
Old Jan 11, 2003 | 10:20 PM
MackSpeed-616's Avatar
is the american racing tire dot approved?
is this the same company that makes those cheezy wheels?
[Modified by BustaNutt-616, 2:22 AM 1/12/2003]
