Already Searched. Need to know if my Del Sol is VTEC or what...
here's what we have so far, it doesn't say VTEC or Si on the back OR on the valve cover, and it doesn't say VTEC on the gauge cluster . . . but according to http://www.accordracing.com/vinnum.htm I have an Si engine. I did a search and the information I found seems to be conflicting, I've read that all Si engines are SOHC VTEC's. If my car has VTEC then there must be something wrong with it because I cant feel it kick in, and I'm sure I would feel it because I pay pretty close attention to my car when I'm driving.
Can I get a definitive answer from somebody who knows?
Thanks alot.
Thanks alot.
read the engine code on your block
then you will know
b16a3 (correct me if im wrong guys) is the Del Sol Si engine.
then you will know
then you will know
then you will know
DelSol Si has SOHC VTEC a.k.a D16Z6 motor. DelSol VTEC has DOHC VTEC a.k.a B16A3
what is your redline???
if you got a 8200 redline, you have dohc vtec
if you got a 7200 redline, you have sohc vtec
if you got a 6800? redline, you have a poop motor that needs vtec..
hope that helps
hope that helps
UM why dont you just OPEN THE HOOD?
if it says DOHC VTEC on it its a b16a3, the fast del slow.
if it dosent have a black valve cover that says DOHC VTEC on it, its an SI
Sterling
12
Jul 17, 2002 06:12 AM
Xyster
Jun 9, 2002 07:43 PM
