4g civic si IM vs. d16z6 IM
Old Jan 9, 2003 | 08:34 PM
4dohs4mohoes's Avatar
Default 4g civic si IM vs. d16z6 IM
im in the process of doing putting a z6 into my 91 dx. I did a search and couldn't find anything about this. But my question is...can I use a 4g si engine wiring harness on a z6 IM. I am using the correct injectors.
Old Jan 10, 2003 | 05:28 PM
IhateMy93BlackHatch's Avatar
Default Re: 4g civic si IM vs. d16z6 IM (lilgreenhonda)
yes u can
Old Jan 10, 2003 | 05:31 PM
USDM 4G VTEC's Avatar
yes u can
i even have a 93 IM conected with my STD wiring harness.... i am using the Z6 trotle body mounted MAP. it sbetter
Old Jan 10, 2003 | 06:27 PM
Mugen Dom's Avatar
well u dont use the si harness ull use ur stock dx harness with some added on peices to make a hybrid harness.....the z6 mani will work fine u loose some bottome end with it but top end u gain some the a6 has more of a torquey feeling to it but not much difference
Old Jan 11, 2003 | 03:24 PM
Default Re: 4g civic si IM vs. d16z6 IM (JdMB16Ahatch)
so the only way to make it work is to conver the dx harness to 4 point. but the si harness already has the 4 point. so thats my ques. will the plugs on the si harness plug up to the z6 manifold. that way i dont have to modify the dx harness. thanks guys
Old Jan 11, 2003 | 03:54 PM
civbeater90's Avatar
Old Jan 11, 2003 | 06:17 PM
Mugen Dom's Avatar
Default Re: 4g civic si IM vs. d16z6 IM (civbeater90)
thats what i said.....
u can not use the si harness cause it wont plug onto ur dx.....rear mpfi swap posts to learn how to do this its not hard the a6 manifold is the same as teh si except that u use the z6 throtle body or a b series throtle body....u cant use the a6 one though.....u can use the si injecters in it and u use the z6 eacv and ur old plug will plug into it
Old Jan 11, 2003 | 09:25 PM
ok i got that...but is there any way that i can use the si IM so i dont have to make that harness? well let me tell ya this. the last time i converted my harness i had a guy do i t for me, and he phucked it all up. so basically im trying to avoid making that harness if possible. sorry for being stubborn
Old Jan 12, 2003 | 12:54 AM
crashtest Sonny's Avatar
hey you got my name in the topic!
Old Jan 12, 2003 | 07:54 AM
Mugen Dom's Avatar
do u have mpfi?????? or the stock dx injection DPFI? if u have the dpfi still then u can keep it and not convert anything
Old Jan 12, 2003 | 03:35 PM
no...right now i have the mpfi Z6 IM. but i can get the 4g si IM for cheap. i have the civic si injectors and ecu but im trying to see if i can chachane IMs so i dont have to covert my harness. sorry if im making ya mad dude.
Old Jan 12, 2003 | 03:47 PM
Louie B.'s Avatar
What people are trying to tell you is you can not use the Si harness because it does not plug into the DX Firewall harness. There's accually LESS modification required to convert the DX harness than there is to try to make the Si Engine harness work with the DX firewall harness. Do the Conversion yourself or get someone more qualified to do it. Like someone who's accually done it before. If done properly, the DX conversion can be very clean and reliable. when I did mine, I was able to do it with NO splices under the hood, and I removed all of the loom and replaced it with all new after I had all of the wires routed. So it looks totally stock.
you mentioned that you have A6 Injectors and ECU, do you have the A6 Inj resistor box, and Distributor?
[Modified by thumpu77, 4:50 PM 1/12/2003]
Old Jan 12, 2003 | 07:10 PM
Default Re: 4g civic si IM vs. d16z6 IM (thumpu77)
oh chit...my bad thats all someone needed to tel me...thatnks alot. and yes i do have all the correct crapola to do this...sorry all of yall. thanks alot though
Tescrash
Feb 17, 2017 05:24 AM
BlendedEM1
Feb 13, 2011 07:06 PM
Suck my DX
Sep 7, 2005 06:32 AM
Suck my DX
Sep 6, 2005 07:27 PM
