burning rich
Old Jan 9, 2003 | 06:35 PM
blueeg's Avatar
Default burning rich
my car has been sitting in my drive way for half a year. i just started it up recently and noticed a big cloud of black smoke everytime i start it up. when its warmed up i only see the black smoke when i step on the gas pedal. doesnt smell that bad when its warmed up compared to when the engine is cold. idle is moving back and forth form around 600-1000 rpm. its a 92 civic hatch dx. not throwing any codes. all stock and oh yeah theres a big hole in the exhaust pipe just before the cat. could it be cat?please help!
Old Jan 9, 2003 | 07:14 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: burning rich (blueeg)
change all your fluids.. oil, tranny fluid, radiator fluid, everything.. if your car was sitting for that long without being ran then it is prolly hurting..
Old Jan 9, 2003 | 07:25 PM
-Whitey-'s Avatar
Default Re: burning rich (Hatchy-Ownzjo0)
you should have never let your car sit that long..change every fluid do a routine tune up and TAKE CARE OF YOUR CAR FROM NOW ON
[Modified by One-Panda, 10:25 PM 1/9/2003]
Old Jan 10, 2003 | 11:12 PM
blueeg's Avatar
cahnged all the fulids. still the same.
Old Jan 10, 2003 | 11:33 PM
Shawn C's Avatar
In The Garage
do a tune-up, and clean the throttlebody/int. man., just give it a good goin over. also, check the vaccuum hose on the fuel pressure regulator, if it has a leak, you will have high fuel pressure and a vaccuum leak, causing it to run rich and have a fluctuating idle.
Breadjunkie
Honda Civic (2001 - 2005)
Apr 18, 2011 09:40 PM
DCshoecompany
Jan 13, 2009 03:28 PM
Fobstylez
May 31, 2005 11:54 AM
B00ST2nR
Mar 2, 2003 10:44 PM
