re-ringed my pistons (not 56k friendly)
Old Jan 9, 2003 | 05:29 PM
Remmy's Avatar
Default re-ringed my pistons (not 56k friendly)
hey all, i dont post here often, but ive been reading this board for close to a year, and others for longer. anyways, i finally got the opportunity to dig inside my cars motor over my christmas break and got to take care of a problem ive had forever in burning oil, like 1 qt. per 300 miles. my grandpa and i tore down the engine and changed the rings, i took my head into our local napa and let them change the valve seals (i didnt want to buy the tools to get them out, and didnt really want to risk messing my head up). anyways, i got to take a few pictures of the opperation.
it's now about 600 miles later and my car is running great, no more burning oil
Old Jan 9, 2003 | 05:31 PM
harryg's Avatar
Default Re: re-ringed my pistons (Remmy)
Red X's for the last three pics. Sounds like a very cool grandpa you've got.. how difficult was the process, was this your first teardown?
Old Jan 9, 2003 | 05:34 PM
JeremyL's Avatar
Default Re: re-ringed my pistons (harrytg)
what are those long rods next to the manifold gasket in the first pic?
Old Jan 9, 2003 | 05:39 PM
project dc2's Avatar
Default Re: re-ringed my pistons (JeremyL)
headbolts
Old Jan 9, 2003 | 05:40 PM
shamoo's Avatar
Will you make something up for me please?
Look like head bolts to me.
Old Jan 9, 2003 | 05:49 PM
Remmy's Avatar
I'll try to post the last 3 again in a minute. My grandpa is awesome, he basically told me everything i had to do to teardown my engine without even touching my helms manual. i really only had to use the book to look up torque specs with him. as far as the difficulty, it was a long challenging job. we got the head of the motor and took it into napa in like 4 or 5 hours. then taking the pistons out was maybe 2 hours (taking off the oilpan and bottom end stuff), an hour to clean them and a half an hour to re-ring them. 2 hours to put them in and secure the bottom end. then when we got the head back from napa it took about 3 hours to get it on and everything secured. took another hour for getting the timing takin care of and making sure it would run alright. we worked for more than 16 hours over the course of 4 days tho (waiting for the rings to come in and waiting for the head to get worked on) and took our time every step of the way.
edit: oh yeah,
those are headbolts, like everyone said before.
[Modified by Remmy, 9:50 PM 1/9/2003]
[Modified by Remmy, 9:54 PM 1/9/2003]
Old Jan 9, 2003 | 05:52 PM
Remmy's Avatar
the last 3 (i hope they work now)
Old Jan 9, 2003 | 05:53 PM
slowdx's Avatar
Did you replace the rod bearings too? How many miles did you have on the motor?
Old Jan 9, 2003 | 05:54 PM
ragejed's Avatar
Please explain the Prestone antifreeze..and tell me you did not use that.
Old Jan 9, 2003 | 05:57 PM
Remmy's Avatar
Default Re: re-ringed my pistons (slowdx)
I kept the original bearings, the motor has 84k on it. the bearings were in good shape, hardly any signs of wear. i just had to be careful that each of the bearings stayed on the rod it came off of, oriented in the right direction, and back into the cylinder it came out of.
Old Jan 9, 2003 | 06:00 PM
Remmy's Avatar
Default Re: re-ringed my pistons (ragejed)
the prestone is just the container that held my radiator coolant when i drained it (it drained into a larger bucket, and i stored it in the empty prestone jug so that i wouldn't spill it when i was rolling around the garage). i reused the coolant from before the teardown, it was fine.
but out of curiosity, what do you have against prestone?
Old Jan 9, 2003 | 06:35 PM
ragejed's Avatar
I wish i knew the thread about the coolant, but honda made their own coolant for a reason. Has special things in it to protect the stock radiators. Prevents corosion(sp?) too.
Old Jan 9, 2003 | 06:41 PM
Remmy's Avatar
i did not know that, learn something new everyday
unfortunately, i spilled some of my coolant in the process and had to make up the difference with some peak antifreeze...we'll see if my radiator craps out anytime soon.
Old Jan 9, 2003 | 06:56 PM
ragejed's Avatar
I would recommend getting some honda coolant in there. For the price, its well worth it.
Compared to the price of a new rad..
Old Jan 9, 2003 | 07:04 PM
94TealGSR's Avatar
Yet another BG-33P GS-R. We need to start a club or something.
Replacing the crank on my GS-R next week... can't wait.
Old Jan 9, 2003 | 07:44 PM
Tweakmeister's Avatar
fantastic post
Old Jan 9, 2003 | 07:45 PM
stumpyf4's Avatar
Default Re: re-ringed my pistons (94TealGSR)
Good Job!!
Honda Coolant "Exclusive formula developed by Honda R&D. Specifically designed for use in aluminum engines. Uses high-tech organic corrosion inhibitors instead of more commonly used silicate corrosion inhibitors. Unlike silicates, HP Coolant's organic corrosion inhibitors won't gel and cause radiator plugging, they're more stable for a longer shelf life, and don't act as abrasives to mechanical water-pump seals to cause leaks."
That's the marketing scheme.
Old Jan 9, 2003 | 09:28 PM
Halo's Avatar
Default Re: re-ringed my pistons (stumpyf4)
great post thank you
Old Jan 10, 2003 | 03:40 AM
JeremyL's Avatar
Default Re: re-ringed my pistons (Halo)
why not just throw some forger higer comp pistons or some ITR/CTR in while you were in there?
Old Jan 10, 2003 | 03:46 AM
2k1_ITR_0736's Avatar
excellent post. im taking on this project tomorrow
Old Jan 10, 2003 | 03:49 AM
Remmy's Avatar
haha, yeah, there is something special about the green ones
Old Jan 10, 2003 | 03:52 AM
Remmy's Avatar
i thought about it, but at the time i didn't really have the money to do that...
but since ive been in there i wouldnt be affraid to swap my pistons out sometime later when i can afford it.
Old Jan 10, 2003 | 03:54 AM
JeremyL's Avatar
i would have suggested too maybe some headwork while it was out too like oversized valves, springs, retainers blah blah blah
Old Jan 10, 2003 | 03:55 AM
Remmy's Avatar
Default Re: re-ringed my pistons (2k1_itr_0736)
im sure you've done your research already on this, but i found this guys documentary of pictures very helpful in undertaking the job. hope it helps.
http://techpage.h-fans.cz/preludka/galerie/page_01.htm
Old Jan 10, 2003 | 03:56 AM
Eva01's Avatar
[QUOTE]Yet another BG-33P GS-R. We need to start a club or something. [QUOTE]
I think I have only seen one other Paradise Blue Green in my town. That looks like some serious wrenching. Nice job!
