How tight do I set the timing belt tensioner?
Old Jan 9, 2003 | 02:43 PM
SC0TT's Avatar
Default How tight do I set the timing belt tensioner?
Im changing the T-Belt on my b16 and I was wondering if there is a certain way I should set the tensioner. How tight should I set it? Thanks-
Old Jan 9, 2003 | 02:55 PM
ScottEK's Avatar
Default Re: How tight do I set the timing belt tensioner? (cr-tegra)
Hmm it says in the manual, dont take my word for this but as far as I could remember you loosen up the tensioner, rotate the crank counterclockwise until the cam gears move three teeth, then you torque the tensioner to spec.
Old Jan 9, 2003 | 02:59 PM
ScottEK's Avatar
Default Re: How tight do I set the timing belt tensioner? (beta13)
BMXman
Apr 12, 2014 08:28 PM
hypnolobster
Jan 24, 2012 08:53 PM
EK FLY
Oct 11, 2011 04:47 PM
TrueUntilDeath.com
Jan 23, 2008 11:07 PM
SHG_EasyE
Mar 9, 2005 10:10 AM
