sohc sputtering at partial throttle....no spark ?
Old Jan 9, 2003 | 01:18 PM
X2BOARD's Avatar
Default sohc sputtering at partial throttle....no spark ?
Ok, this is the deal, 95 D16Z6, I have a code 23 (I think that was the #) For H02S (O2 Sensor) So the aftermarket (not stock) O2 sensor I have may be gone... but the distributor cap/rotor look ok.
When at partial throttle in any gear, only at lower rpm, like 2-3K, if I give it some gas, it goes and gives a little sputter a couple times until/unless I put the gas down (basically raise the rpm) the sputtering stops and the car accelerates briskly.
EgI: Pulling off in 1st, calmly... the engine purrs, engaging clutch, intially car will start to sputter/hesitate, but if I give it more gas... the sputter stops.
EgII: If I were crusing along at say 40 and I put it in 5th and give it a little gas, the engine will sputter some until I get higher in the rpm band.
Any one have this problem ? Any diagnosis' ?
The plug wires are Accell POS... I need some stockers.... the plugs are pretty new.
X2
Old Jan 10, 2003 | 09:53 AM
X2BOARD's Avatar
Default Re: sohc sputtering at partial throttle....no spark ? (X2BOARD)
anyone ?
Old Jan 10, 2003 | 11:07 AM
SRT-WHORE's Avatar
Sounds like either the coil, distributor, or both.
Old Jan 10, 2003 | 10:40 PM
X2BOARD's Avatar
Default Re: sohc sputtering at partial throttle....no spark ? (SILINITY16)
up
Old Jan 11, 2003 | 12:53 AM
IDriveHonda's Avatar
try replacing the O2, do you have 1 or 2 O2 sensors?
Old Jan 13, 2003 | 09:50 PM
X2BOARD's Avatar
Default Re: sohc sputtering at partial throttle....no spark ? (IDriveHonda)
just 1.... I am OBDI blessed....heh heh...
h_civ2000
Nov 20, 2010 12:30 PM
ShinotakuX
Feb 7, 2008 06:54 AM
bboixtc
Dec 17, 2007 06:02 PM
SIK IN DA HED
Nov 22, 2002 03:43 PM
