Anyone have any "how to" install new brake pads?
Old Jan 9, 2003 | 12:37 PM
Nocturnal's Avatar
Default Anyone have any "how to" install new brake pads?
I have a 93 Si, and I want to change my brake pads. A shop wants to charge me $75.00 + tax for the installation. I'm just wondering how hard it will be for me to do the change? I have air tools and I can get whatever hand tools as well. I don't know about the C Clamp, but I sure as hell can charge one on my Sears credit card. Help!
Old Jan 9, 2003 | 12:39 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Anyone have any "how to" install new brake pads? (psychotic)
very easy. Swing caliper away and install. Just get a Haynes/Helms/Chilton or whatever you can. Tell you everything you need to know.
Old Jan 9, 2003 | 12:40 PM
-Whitey-'s Avatar
did u even think about taking the wheel off and looking at it?
its common sense just take it apart and oput it all back together the same way it came apart..do one wheel at a time so if you mess up you have a refrence good luck
sydag5's Avatar
Any helms, haynes manual will tell you how to do it. It's pretty straight foward
Old Jan 9, 2003 | 12:41 PM
Nocturnal's Avatar
Default Re: Anyone have any "how to" install new brake pads? (Emerica)
You see, I have $75.00 for the brake pad installation. The Helms manual is $68.00 shipped. If I can do the brakes myself I can easily buy the Helms manual which would definately come in handy down the road. I don't know what to do.
Old Jan 9, 2003 | 12:44 PM
-Whitey-'s Avatar
what the hell? go to a local auto parts store and buy the helms manual for 10-12 bucks..68 shipped ? thats way to much i think your trying to get a diffent manual
Old Jan 9, 2003 | 12:48 PM
Nocturnal's Avatar
Default Re: Anyone have any "how to" install new brake pads? (one-syk)
You're talking about a Haynes, not a Helms. Go to http://www.helminc.com. They have the manuals for $66.00, not $12.00.
Old Jan 9, 2003 | 12:50 PM
Luserkid's Avatar
unbolt the screw thats holding the caliper (i think its a 14mm but i could be wrong) then pull the caliper up, take off the old pad (match it with the new to make sure its right) then screw it back on..... thats basically it.... but if you got back disc brakes then your gonna have to do more cause of your parking brake, but its basically the same. good luck
Old Jan 9, 2003 | 12:52 PM
-Whitey-'s Avatar
Default Re: Anyone have any "how to" install new brake pads? (Luserkid)
heh your right i was thinking of a diffrent manual the 12 dollar manual is prettuy much all you need to do basic **** like this though it will save you some money too for tools or food or parts
Old Jan 9, 2003 | 12:53 PM
Kamin's Avatar
DUDE you really dont think thats a helms right?!?!
thats a HAYNES or a CHILTON
they are like a cliff notes version of the helms.
and yes the helms is 70$ but you will use it 1000+ more times now because you have it.
well worth the money.
Old Jan 9, 2003 | 01:00 PM
-Whitey-'s Avatar
Default Re: Anyone have any "how to" install new brake pads? (Kamin)
i dont think you read the post i made before you made this one i said i was wrong and thinking about the wrong book
Old Jan 9, 2003 | 01:15 PM
funky_cornbread's Avatar
some links i found, might help ya out.
http://www.g2ic.com/tegtips/exterior/15.html
http://www.batauto.com/articles/frntbrks.shtml
http://www.importtuner.com/tech/0206it_bigbrakes/
just trying to help.
Old Jan 9, 2003 | 04:41 PM
Nocturnal's Avatar
Default Re: Anyone have any "how to" install new brake pads? (funky_cornbread)
Thanks I truly appreciate the effort you guys put into this forum for some unknown guy from Hawaii. You guys own. The brakes look like it is an easy job to do. Doesn't look too complicated. The only part I am kinda not getting is after you take off the top or bottom bolt off the caliper, you are supposed to use a C-Clamp to hold the piston down? How do you accomplish this? How hard is it to do this?
Old Jan 9, 2003 | 04:56 PM
tominos's Avatar
you use the c clamp to push the piston back into it's bore. make sure that your master cylinder doesn't overflow when you do this. it's damn easy.
Old Jan 9, 2003 | 05:01 PM
Nocturnal's Avatar
Default Re: Anyone have any "how to" install new brake pads? (tominos)
How big of a C-Clamp will I need? I need to go buy one tonight. I don't have any at my house right now.
Old Jan 9, 2003 | 05:08 PM
Bondel Slo's Avatar
You can always do it the cheap and easy way with a pair of vice grips and a 3/8" drive extension.
Old Jan 9, 2003 | 05:11 PM
ablangc's Avatar
Default Re: Anyone have any "how to" install new brake pads? (Bondel Slo)
once you have done changing the brake pads, you will laugh and wonder how mechanics can charge 70 dollars or more for labor??????
Old Jan 9, 2003 | 05:13 PM
Nocturnal's Avatar
No **** huh? My friend wanted to charge me $45.00 for labor per hour and then $30.00 to resurface my rotors. I was like **** I can do this myself, can't I? And he was like "Yeah." So, I'm gonna do it myself. **** the bullshit. Thanks for all the help. This forum rocks.
Old Jan 9, 2003 | 05:54 PM
Evs-One's Avatar
Solbros Owns Me
check the thickness of the rotors too, to be on the safe side. I know the Napa by my house resurfaces rotors for 10 bucks a piece.
jrv2u
Jul 1, 2005 07:34 PM
alotawatts
Nov 11, 2004 03:30 PM
ssbgsr
Mar 12, 2003 07:12 AM
Chris y0!
Jan 5, 2003 01:12 PM
