Clearences for 500whp b16
Old Jan 9, 2003 | 12:10 PM
The sweed's Avatar
Default Clearences for 500whp b16
The clearences for the main bearings to the crank is in my workshop book for new bearings 0,024-0,042 mm and for the main bearing nr 3 in the middle 0,030-0,048mm
And the clearences for the crank to rod bearings 0,032-0,050mm
That is for a total stock engine. It´s a b16a2 and I go with stock crank, crower rods and endyn/RW 84,5mm pistons. This is my first assembly of a car engine and the dragracers that runs 1000hp volvos in sweden told me that i should increase clearences on a high output engine so they made me unshore.
Should I stay by the stock clearences or what do you guys think......
[Modified by The sweed, 1:13 PM 1/9/2003]
Old Jan 9, 2003 | 12:18 PM
sgT's Avatar
sgT
Default Re: Clearences for 500whp b16 (The sweed)
you can make more power if you stay to the loose end of the factory specs
Old Jan 9, 2003 | 09:33 PM
The sweed's Avatar
I go wit the stock spec ..thanks
integra3586
21
Oct 30, 2009 09:16 PM
blackcrx16
Oct 14, 2007 08:02 PM
Cheefed
Jul 22, 2007 01:16 AM
ivt-t
Oct 5, 2005 07:20 AM
94civickid
Mar 15, 2005 02:10 PM
