Ls/Vtec head gasket q's
Old Jan 9, 2003 | 10:29 AM
zCivic's Avatar
Default Ls/Vtec head gasket q's
Ok I know to use the LS head gasket. I want a 2 layer head gasket. All I can find in 2 layer is for the V-tecs and that wont work. So can I use a OEM 3 layer and just leave one out or how can I do this correctly.
Old Jan 9, 2003 | 08:08 PM
smokey2.0's Avatar
Default Re: Ls/Vtec head gasket q's (zCivic)
it's not that hard, too bad you're in Tn. i could probaly set one up for you, in ten minutes!
Old Jan 10, 2003 | 01:48 AM
slowassgsxr750's Avatar
Default Re: Ls/Vtec head gasket q's (smokey2.0)
just take one layer off,its run fine,i just ran one layer on my motor,had no problems
Old Jan 10, 2003 | 04:17 AM
zCivic's Avatar
Default Re: Ls/Vtec head gasket q's (singleslamrex)
So just use 2 of the OEM gaskets. Which 2 would I use??
Old Jan 11, 2003 | 10:19 AM
i only used one,i used the bottom layer,but i tryed them all and they all work good
Old Jan 11, 2003 | 12:35 PM
ghettocrxsi's Avatar
omg plz do not listen to any of them... what u do is take out the rivets... and sepparate the head gasket .. There is a metal layer in the middle and u need to clean it with some break cleaner... then buy some mr gasket copper spray... hang up the gasket and spary it on both sides with the copper spray.. .wait a few minutes till its tackey then install it.. its easy and bumps compression a few points.. just like a spoon hg
krazych0p
Nov 10, 2008 01:38 PM
eh2-hb
Oct 13, 2005 10:01 PM
tegmaniac
Apr 24, 2003 11:20 AM
zCivic
Jan 9, 2003 09:56 AM
