anyone know the d16a6 piston to dome height?
Old Jan 8, 2003 | 08:38 PM
altoid's Avatar
Default anyone know the d16a6 piston to dome height?
Im looking into bumping up my comp soon and i wanna know the piston to dome height so i can use that spiffy c-speed comp calc... Here's what i've got so far
Combustion chamber = 38cc
Bore = 75 mm
Stroke = 90 mm
OEM 3 layer Gasket = 0.0290 (im actually going to be using the y8 gasket so any corrections will be gratefully appreciated)
So now i just need the piston to deck height, and i can't afford and don't have the tools to pull of my head and figure it out as this time. Thanks
Old Jan 9, 2003 | 04:34 AM
RevinRex's Avatar
Default Re: anyone know the d16a6 piston to dome height? (altoid)
D16A6 Piston-to-Deck Clearance = 0.020 in
Stock D16A6 Head Gasket = 0.048 in
Stock D16Y8 Head Gasket = 0.037 in
Old Jan 9, 2003 | 08:19 AM
altoid's Avatar
Default Re: anyone know the d16a6 piston to dome height? (YBLegal)
12.116864326611375:1 c/r with pct pistons in case of any confusion...anyone know if a usdm honda dealer would sell the ctr piston sets?
Old Jan 9, 2003 | 09:41 AM
ExospeedAMcrx's Avatar
PCT piston. in a D block is that what you are trying to do?
Old Jan 9, 2003 | 06:29 PM
altoid's Avatar
Default Re: anyone know the d16a6 piston to dome height? (exospeedAMcrx)
im looking at various combos and making a judgement call from there, so not necessarily pct pistons but possibly...I found on d-series.org someone said the combustion chamber of the d-series is something like 32.8 cc not 38...if thats the case the compression is around 14.00:1 thats wicked sweet
Old Jan 9, 2003 | 10:55 PM
chasrex's Avatar
http://www.flashcow.com/dseries/compression.html
A work in progress. All the default values are for a stock D16A6. 1 inch = 25.4 mm.
32.8 cc's corresponds only to the Y5 and Y8 heads in the US. Z6 head volume is 34.6 cc's
Chas
Honda D Series
http://dseries.org
Old Jan 10, 2003 | 05:25 AM
RevinRex's Avatar
Default Re: anyone know the d16a6 piston to dome height? (chasrex)
Also, the A6's Head Chamber Volume is 38 cc's.
chasrex is correct on the Z6 and Y5,Y8 heads.
EDIT: Shoot..you already mentioned it in your first post! Oups!
[Modified by YBLegal, 10:27 AM 1/10/2003]
Old Jan 10, 2003 | 05:33 AM
RevinRex's Avatar
Since you want to raise your comp in your A6, I'd suggest A1 pistons and maybe a 92-95 si head gasket.
CR with A6 gasket and A1 pistons = 11.35 CR and 1590.61 Displacement
CR with Z6 or Y8 gasket and A1 pistons = 11.67 CR and 1590.61 Displacement
I'll be doing this setup in the near future along with cams. I'm saving up for it now! Hope this helps!
Old Jan 26, 2003 | 06:08 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Holy Jeez that's crazy-*** CR numbers!
What about stock D16A6 pistons with the D16Y8 head gasket?
Old Jan 26, 2003 | 06:53 PM
jasonb's Avatar
Default Re: anyone know the d16a6 piston to dome height? (B18C5-EH2)
my question as well
Tc125a
Apr 1, 2019 03:49 PM
H-allmotorda9
Feb 5, 2010 02:42 PM
ge_itr
Jan 24, 2008 09:59 AM
Si Shane
May 22, 2005 08:54 PM
omega11855
Dec 28, 2003 04:21 PM
