Oil Inlet for Turbo Too Big for my Oil Feed Line?
I recieved a male/male 90' fitting for my Oil Feed from RevHard along with some flanges that I ordered. (BTW:
for quick and quality service from RevHard).
My oil feed consists of a SS line with earls fittings. The 90' fitting should go from my last female fitting in the line setup directly into my turbo oil inlet. However that 90' fitting only fits my line and is too small for the turbo inlet.
The turbo's the Garrett 4 bolt with .48 turbine housing / .60 compressor housing.
Is there a fitting that could convert the 90' fitting into the larger oil inlet?
ie:
90' fitting -> converter (small female inlet, larger male outlet) -> female turbo inlet
*all fittings are NPT*
I'll never be boosted.
for quick and quality service from RevHard).My oil feed consists of a SS line with earls fittings. The 90' fitting should go from my last female fitting in the line setup directly into my turbo oil inlet. However that 90' fitting only fits my line and is too small for the turbo inlet.
ie:
What up man. This is Sebastian. Do you have any pictures?
lemme make sure bI underdstand you...You got an oil feed line, with female ends right? and then you have a fitting that can screw into the female end, but is too small for the oil feed on your turbo? How small? Do you screw it right into the turbo, or did you get a feed flange too?
Ill be home soon on my normal name..
CivicDude2k4
Sep 5, 2006 08:24 PM
