Civic Tire Size
Old Jan 8, 2003 | 04:34 PM
oldguy's Avatar
Default Civic Tire Size
i am in the process of building a street only 92 H/B with a turboed H22 i am going to run B.F. goodrich g-force T/A kd's with the H/R coil overs. i am looking to find out if anyone has a reccomendation for wheel size[15or 16] tire size[205/50-15-225/50-15up to225/50-16] thanks for any help!
Old Jan 8, 2003 | 05:51 PM
qcoffey's Avatar
Default Re: Civic Tire Size (oldguy)
Normally the 205/50/15 would be the size of choice based on the factory size for that car. Since you are running a different drive train I wonder if you should run a size that would be appropriate for a Prelude(I'm assuming that is where the drivetrain has been sourced). What I am saying is that a 205/50/15 has an overall diameter smaller than a stock Prelude that came with 205/55/15('92-96) or a 205/50/16('97-00). This tire size has an overall diameter that is approximately 1" larger than a 205/50/15. A 225/50/15 would have a size that is almost identical to the factory '92-96 size. I know I have just babbled off a lot of junk, I just hope it helps.
May 22, 2006 03:35 PM
draperj09
May 2, 2006 08:51 AM
onecamsivik
Mar 2, 2005 11:13 AM
whagkangmakulet
Aug 22, 2002 05:39 PM
