HELP!!! How in the FOOK do you put a front license plate on the R?!
Old Jan 8, 2003 | 01:38 PM
io_burn's Avatar
New User
Default HELP!!! How in the **** do you put a front license plate on the R?!
Ok, so I got my license plates today, tore off my temp tags, and I am completely dumbfounded as to how you get license plates on the front of the R. I went out and bought both kinds of mounting kits Pep Boys had, and none of the screws are big enough. I assume you don't want to just screw it in to the front bumper... But how in the hell... It's getting dark and I'm getting frustrated, anyone have any tips?
Thanks!
Edit: I'm going out in about an hour and with my current track record of getting pulled over all the damn time I'd say there's about a 70% chance I'd get a ticket for driving without one tonight.
[Modified by io_burn, 4:43 PM 1/8/2003]
Old Jan 8, 2003 | 01:41 PM
Bbasso's Avatar
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (io_burn)
Get the "Y" bracket from Acura it makes life easy.
zijiejijeijrkjk's Avatar
Check the spare tire well. Might be a mounting kit in there
Dropspeed's Avatar
OH, I don't know if I would admit that you can't install a front plate J/K
There are two little bumper plugs on the front bumper, Remove them and there are threaded inserts ready to put lic. plate scews in place.
Mattj
Chris N's Avatar
There's a mounting bracket that gets screwed in on the front air dam/grill/whatever you want to call it. Maybe you are missing this mounting bracket???
Old Jan 8, 2003 | 01:43 PM
Nate B's Avatar
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (Chris N)
Get a Helms
Old Jan 8, 2003 | 01:44 PM
io_burn's Avatar
New User
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (Nate B)
I have the mounting bracket, I'm talking about getting the screws IN to the front bumper.
Old Jan 8, 2003 | 01:45 PM
righty tighty
lefty loosey
Old Jan 8, 2003 | 01:47 PM
YumVTEC's Avatar
take off the caps over the screw holes
Old Jan 8, 2003 | 01:50 PM
sgT's Avatar
sgT
there are two holes for 10mm bolts in the front bumper.
if you cant see them..... get some glassses
Old Jan 8, 2003 | 01:52 PM
io_burn's Avatar
New User
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (sgT)
The problem: (I think I'm missing the threaded piece inside of the bumper :\ )
See, this is where I H-T from:
Old Jan 8, 2003 | 01:53 PM
sgT's Avatar
sgT
yeah, you are missing those threaded inserts.
Old Jan 8, 2003 | 02:00 PM
Chris N's Avatar
Who needs a front license plate, anyway?
Chris - who notes that no Illinois policeman has bothered him and his missing front plate.
Old Jan 8, 2003 | 02:06 PM
io_burn's Avatar
New User
I got a warning and two tickets in my CRX with no front license plate... My front bumper was fucked up and it wouild NOT hold the plate, so I eventually just ended up zip tieing it around the whole thing....
Naperville cops
Old Jan 8, 2003 | 02:07 PM
Asahi's Avatar
THe car been wrecked beforre? THe bumpers don't come with those inserts they have to be bought seperate on replacement bumpers.
Trey
Old Jan 8, 2003 | 02:08 PM
Reid's Avatar
Global Moderator
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (py1091)
Put a ziptie through the holes and ziptie your license plate on.
Zipties are lighter than bolts.
Chris N's Avatar
Hey, #1091. 2001? Interesting. You are in the chicago area? Me (#1107), Nate (#1111) and another (I *think* 1096) are all in the area....
Anyhoo, ioburn - You may not be able to get the plugs to fit if you are missing the 'insides' where the bolts screw in. Not sure....
jeffrey's Avatar
i used zipties.
Old Jan 8, 2003 | 02:09 PM
Asahi's Avatar
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (Bbasso)
The Y bracket will work without the inserts BTW. BUt you can't put the factor plugs into the bumper holes without the inserts either
Old Jan 8, 2003 | 02:12 PM
RTW DC2R's Avatar
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (Asahi)
duct tape that bastard on, no rattling
Old Jan 8, 2003 | 02:32 PM
io_burn's Avatar
New User
Trey: Porters at Acura banged up the front driver side of my car... I swear my R is ******* cursed.
Old Jan 8, 2003 | 02:47 PM
98type_r's Avatar
New User
then you'll need to buy the 2 clips for the bumper for the screws to feed through. and you'll need to remove the bumper to put those pieces on.
Old Jan 8, 2003 | 03:03 PM
Asahi's Avatar
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (tie par)
Just use the Y bracket mentioned above. It doesn't use the holes shown.
Old Jan 8, 2003 | 03:12 PM
HiRevn's Avatar
Looks like it's time for an engine wash. Seems pretty dusty under the hood.
Old Jan 8, 2003 | 03:26 PM
R1525's Avatar
Default Re: HELP!!! How in the **** do you put a front license plate on the R?! (HiRevn)
nice PY CAI.....
