HELP : Lo Beams Not Working!!!
Old Jan 8, 2003 | 01:24 PM
hagrid's Avatar
Default HELP : Lo Beams Not Working!!!
when i turn the switch once to where my corners and interior lights come on, nothing happens, when i turn again for lo beam, interior, and corners, still dosn't work. nothing comes on excect my dash lights. when i go to high beam, everything comes on. can anyone tell me what happened?
Old Jan 8, 2003 | 01:30 PM
YeuEmMaiMai's Avatar
Default Re: HELP : Lo Beams Not Working!!! (5th Gen)
sounds like you have some wiring issues didn't you have problems with your clock or something else along those lines?
was your car in an accident?
Old Jan 8, 2003 | 01:53 PM
Desslok's Avatar
Default Re: HELP : Lo Beams Not Working!!! (YeuEmMaiMai)
Check the bulbs, when the low beams go out they can cause wierd issues. Otherwise I would suspect your column switch.
Old Jan 8, 2003 | 02:31 PM
Stew Pidasso's Avatar
Make sure you didn't pop a fuse tinkering around with your other wiring issues. Sounds like a crossed wire or bad column switch. Do you have indiglo guage faces?
Old Jan 8, 2003 | 02:54 PM
hagrid's Avatar
Default Re: HELP : Lo Beams Not Working!!! (Stew Pidasso)
no i don't. i fixed the lo beam problem, yes you were right, bad wiring. ok this is my problem now.
when you turn it once, your dash and corners come on correct? well my corners don't come on. they only come on with lo beams.
Old Jan 8, 2003 | 03:00 PM
DrunkNRacer's Avatar
the corners come on with the low-beams.. correct? if so... sounds like a module problem. The location of the module is to the left side of the dash near the centre console (very close to the gas pedal area), there is a cluster of 3 components: Shifter Interlock module, PGM-FI Main Relay and Daytime Running Light module (if you have a manual transmission then there will also be a starter cut relay as well), the DRL should have a 14 pin connector.
There is not any published information for repair of the module, once the diagnosis of a failed module the factory procedure is to replace the module, if you have a background in electronics it is possible to repair it using components from a place like Radio Shack
[Modified by SlowAssAccord, 7:01 PM 1/8/2003]
[Modified by SlowAssAccord, 7:16 PM 1/8/2003]
Old Jan 8, 2003 | 03:48 PM
hagrid's Avatar
Default Re: HELP : Lo Beams Not Working!!! (SlowAssAccord)
turn signals don't work. so i can't drive right now, cause i can't afford another ticket.
Old Jan 8, 2003 | 05:43 PM
Starrman85's Avatar
i kno on my 4th gen...i blew my dome light fuse...which i found out controls all the interior lights and one set of the corner bulbs, cuz i'm not sure about 5th gens, but in 4th gens, there are two bulbs in each corner, when u turn the switch once, they both came on, but when my fuse blew, only one set came on, the ones that blink....so maybe u should check fuse.
Old Jan 8, 2003 | 06:18 PM
hagrid's Avatar
Default Re: HELP : Lo Beams Not Working!!! (STARRMAN85)
what a coincidence. my dome light fuse blew too,,, but that was while back..
hybridnorth
37
Feb 16, 2019 06:13 AM
Iloveyourhonda92
May 10, 2010 09:29 PM
MurdersV8s
Lighting
Sep 16, 2008 05:49 AM
teggy182
Jul 28, 2008 05:38 PM
eg8000rpm
Apr 27, 2005 12:37 PM
