Fram Oil Drain Plug?
Old Jan 8, 2003 | 12:25 PM
JLange's Avatar
Default Fram Oil Drain Plug?
does anyone have this, where you have to just stick the piece of hose into the plug, not even unscrew it from the pan, and it drains out? im considering getting one of these, just wondering if it has flaws
Old Jan 8, 2003 | 12:31 PM
ragejed's Avatar
Default Re: Fram Oil Drain Plug? (jtintegra)
Just get an autozone magnetic plug
Old Jan 8, 2003 | 12:46 PM
tnoskilz's Avatar
I've been using one for about 6 months now...the hose is worthless, but it works really well without the hose. very quick to drain the oil.
Old Jan 8, 2003 | 12:59 PM
skunkintegra's Avatar
Default Re: Fram Oil Drain Plug? (tnoskilz)
I'm interested in this topic!!!
So getting a plug where you can remove an inner bolt, and not ream out the oilpan.
anyone run into any problems with them?
would they prevent any harm to the oilpan...like stripping?
Old Jan 8, 2003 | 01:10 PM
emr88's Avatar
Default Re: Fram Oil Drain Plug? (skunkintegra)
I think it's called SureDrain (www.fram.com), anyways
I have one of these. Not worth the $$$ IMHO. As someone already mentioned, when using the hose it's worthless, it drains way tooo sloow. Basically you replace your oil drain bolt with this valve that is only activated when you attach the little hose with spring clip inside it. It does has a nifty looking cover to protect the valve.
Looking back, I'd rather spend the $$$ on oil filters and drain plug washers.
[Modified by emr88, 10:19 PM 1/8/2003]
Old Jan 8, 2003 | 04:53 PM
Tweakmeister's Avatar
Default Re: Fram Oil Drain Plug? (emr88)
search google, there is a review of them on a corvette webpage.
eh, they're okay.
98bwahhek
12
Feb 7, 2013 09:04 AM
mish__
Nov 16, 2010 07:52 PM
vannak_5415
Oct 6, 2008 05:34 PM
Nos4R2
Jul 1, 2003 06:09 AM
Mires
Sep 21, 2002 08:16 AM
