stock itr ecu in gsr?
Old Jan 8, 2003 | 09:16 AM
b18cu's Avatar
Default stock itr ecu in gsr?
will the stock itr ecu work in a gsr(98 itr ecu in 00 gsr)
Old Jan 8, 2003 | 09:21 AM
uNF$@#!'s Avatar
Default Re: stock itr ecu in gsr? (b18cu)
it'd work, but kiss your motor goodbye.
Old Jan 8, 2003 | 09:25 AM
vtec.dc2's Avatar
the following is "i'll try to help but not sure" information:
it should work, although its programmed for itr cams, i thought it might need a harness due to different wiring in 00 models..
Old Jan 8, 2003 | 09:26 AM
uNF$@#!'s Avatar
Default Re: stock itr ecu in gsr? (vtec.dc2)
try revving a gsr valvetrain to 8400.
Old Jan 8, 2003 | 09:27 AM
b18cu's Avatar
Default Re: stock itr ecu in gsr? (Soup ****)
isnt it a different set up or something wasnt alot of stuff changed for that year(00) like laser keys
Old Jan 8, 2003 | 09:28 AM
vtec.dc2's Avatar
good point, forgot about that... therefore not a good idea
Old Jan 8, 2003 | 09:31 AM
b18cu's Avatar
did i say the valvetrian was stock
Old Jan 8, 2003 | 09:36 AM
GokuSSJ4's Avatar
the only problem is since the gsr manifolds has secondaries they will not work .
Old Jan 8, 2003 | 09:38 AM
vtec.dc2's Avatar
http://hondata.com/adapters.html - i thought about obd2a and obd2b.. although it changed after 98 so it should not apply
Old Jan 8, 2003 | 10:21 AM
ArmyGreenITR's Avatar
it may not work the 00-01 obd2 gen2 ecu have an embolieizer so your 98 GSR might not be able to use it,also you had better have a free flowing manifold (i.e. skunk2 or a JG)because the itr ecu will not open your secondaries makeing your car run like ***,your best bet if you have a diffrent manifold would be to find a 97-98 ITR ecu.
steve
Old Jan 8, 2003 | 10:30 AM
SurferX's Avatar
Default Re: stock itr ecu in gsr? (ArmyGreen EG)
Haha, well if I put an ITR part in my car it means it will make it go faster.
Reminds me of that Carfax commercial, "people do strange things to their cars"
Old Jan 8, 2003 | 11:21 AM
Lost Motion's Avatar
A friend of mine has one in his gsr. You will need a jumper harness to get it to work.
Old Jan 8, 2003 | 12:01 PM
SurferX's Avatar
Wouldn't the secondaries on the GS-R stay open instead of closed? When the IAB solenoid valve is turned off that is when the butterflies are open. Since the Type R ECU has no control for the IAB solenoid I would assume it would just stay off and leave the secondaries open full time.
Old Jan 8, 2003 | 12:18 PM
scooter's Avatar
Default Re: stock itr ecu in gsr? (SurferX)
I am selling a 98 ITR ecu. email me.
scott
98 ITR turbo
Old Jan 8, 2003 | 07:47 PM
ITR#132's Avatar
I cant remember which years, but you are sort of correct. Some years it will stay open all the time and others it will stay closed. I believe it was the way IAB solenoid was hooked up.
[Modified by ITR#132, 8:48 PM 1/8/2003]
Old Jan 8, 2003 | 09:28 PM
:jdmshmaydm:'s Avatar
No. I've tried and no luck. The emmobilizer owns you, and you'll go no-where.
Old Jan 8, 2003 | 09:56 PM
nfn15037's Avatar
Default Re: stock itr ecu in gsr? (ITR#132)
Always open. Youll just loose some bottom end.
Old Jan 8, 2003 | 10:05 PM
spoon_ek9's Avatar
Default Re: stock itr ecu in gsr? (nfn15037)
just wondering, did anyone notice that 98 ecu should be OBD2 ver 1 and 00 ECU should be OBD2 ver 2?
about the redline, i don't see any problem reving to 8400rpm with stock cam. i used to have a gen 2 b16a with spoon ecu, rev it to 9k rpm with stock cam everyday, and every track event for a whole year. i am happy with it, so do the guy who i sold my engine to.
Old Jan 9, 2003 | 02:41 PM
scooter's Avatar
Default Re: stock itr ecu in gsr? (spoon_ek9)
There are no Immobilizer's in 97-98 Ecu's.
scott
98 ITR turbo
gsrboost
Jun 22, 2006 10:41 AM
MaGoodc2
Apr 16, 2006 08:15 PM
Scubster
Dec 21, 2004 10:21 PM
rsx03
Mar 27, 2002 06:59 PM
1fastGSR
Aug 19, 2001 09:13 PM
