tach wire at ecu?
Old Jan 8, 2003 | 06:38 AM
xXx Justin xXx's Avatar
Default tach wire at ecu?
i want to wire the green wire for my tach to the ecu harness. no tach in dash. it is a 94 cx hatchback. i know this isn't the forum.... but if you know which pin it is on a crx... i have a conversion ecu harness... i could trace the wire and figure out the pin for myself... thanks a lot... i need it asap!
Old Jan 8, 2003 | 07:08 AM
spettinger's Avatar
Default Re: tach wire at ecu? (SOHC Beast)
on the crx harness, i believe the pin is located on the middle plug, top row, 3rd in from the right. this is facing the ecu. this pin is normally empty.
Old Jan 8, 2003 | 07:06 PM
Default Re: tach wire at ecu? (2ndhandCRX)
3rd from the right.... looking at the pin side of the clip, or the wire side? and why would it be empty... there should be a tach signal wire? but thanks... anybody else know if this is right?
Old Jan 8, 2003 | 08:33 PM
the DR.'s Avatar
i THINK its pin B15 (?) should be a blue wire
Old Jan 9, 2003 | 03:43 AM
Default Re: tach wire at ecu? (SlicedBread)
o, thanks....
Rich Pedraza Jr
Jul 30, 2009 06:18 AM
si90rex
Jul 13, 2006 12:08 PM
Ray
Jun 24, 2001 11:48 AM
Ray
Jun 23, 2001 07:21 PM
Ray
Jun 18, 2001 11:02 AM
