JDM H22 pulleys
Old Jan 7, 2003 | 08:28 PM
mdjplay's Avatar
Default JDM H22 pulleys
My crankshaft pulley broke. So, I was thinking of going ahead and upgrading to an UNORTHODOX kit. However, my Prelude is my everyday driver, and reliability is very important to me. Would I be smarter to go back stock... at least for the crankshaft pulley? Any ideas? Thanks.
Old Jan 7, 2003 | 08:41 PM
mdjplay's Avatar
Default Re: JDM H22 pulleys (mdjplay)
Also, does anyone know for sure if OEM H22 pulleys will match the JDM ones? Cause my A/C, alternator, and inside crankshaft pulley are all 5 spoked... meanig it would take a 6 ribbed belt. I thought this could be one of the differances with JDM and OEM.
Old Jan 8, 2003 | 09:38 PM
SuperSH's Avatar
If you can replace the crank it would be wise to replace it with an OEM one of the same exact kind if possible. An undampened unorthodox crank pully is hard on crank bearings. I don't know what you mean about the diffrence between JDM and an OEM part that is made in japan. Did you mean the crank pully came off a JDM motor compared to a USDM one?
Old Jan 9, 2003 | 04:52 AM
KGAccord's Avatar
Default Re: JDM H22 pulleys (SuperSH)
no they are the same crank pulley
Old Jan 9, 2003 | 05:52 AM
satan_srv's Avatar
Default Re: JDM H22 pulleys (KGAccord)
I have an Unorthodox Crank Pulley H22a if you want to buy it from me. Make me an offer.
[Modified by satan_srv, 9:53 AM 1/9/2003]
Old Jan 9, 2003 | 06:36 AM
2point6's Avatar
Default Re: JDM H22 pulleys (satan_srv)
$2
Old Jan 9, 2003 | 03:13 PM
Cottonwoodz's Avatar
No they are not the same. The JDM ones have one less rib on it, atleast mine did. Had to switch the JDM one for my H23A1, because it had one rib missing on the air/alt part of the crankpully. I should of taken the A/C out then, but oh well.
badassmthr4000
Sep 4, 2007 08:53 AM
liquid51
Nov 29, 2002 01:09 PM
