Adj. Cams and cam shafts
Old Jan 7, 2003 | 08:21 PM
UnionCity LS's Avatar
Default Adj. Cams and cam shafts
just wondering- 99 Ls...and i was thinkin goin cams...would i need to buy a cam shaft and adj cams...would that be better to do..or can i just buy the adj. ?
<U></U>
skunk2 short shifter
dc ceramic coated headers
aem cold air
aem power pulleys
greaddy cat back exhaust
ground controls
koni reds
Old Jan 7, 2003 | 09:46 PM
iH8RICERZ's Avatar
Default Re: Adj. Cams and cam shafts (99LsTeg)
if you get cams....it would be the best to install the adj cam gears at the same time. Adj cam gears will enable you to advance or retard your intake and exhaust cam. The more aggressive cams you get, the more you better have your head built to handle it!
hondacrx2
May 31, 2007 06:51 PM
Fl1pkidd
Jan 23, 2007 04:41 PM
manyakiexpi
Oct 18, 2006 04:16 PM
NA JDM GSR
Feb 28, 2005 01:49 PM
01integraLS
Aug 1, 2003 12:28 PM
