What HID kit will fit 90-93 JDM Integra headlights?
The bulb is H4H. I'm not sure whether or not a standard H4 bulb (and thus an H4 HID kit) would fit, or could be modified to fit. If not, it might be possible to import an H4H HID kit from Japan, though I'm not certain one even exists. HTH slightly.
i'll get in touch with a couple USAF contacts in japan and see if a H4H kit exists. gimme a week or so.
just a little FYI, HID's aren't meant to be passed through a "scattering" lens/beam pattern like the 90-93 (USDM and JDM both) headlights. they are meant to be used in a focusable beam setting; therefore you won't get quite the effect and may (actually you probably WILL) get flashed by pretty much every car you pass.
Keep in mind that the DA headlights (USDM or JDM) weren't designed for HIDs and refract/reflect the beam all wrong...but it has been done before...look here:
http://www.g2ic.com/forums/showthrea...&highlight=hid
ricky00
Jan 28, 2011 03:25 PM
vexx7001
Oct 12, 2005 11:10 PM
